Author Topic: block colors Just for fun.  (Read 9049 times)
February 07, 2013, 10:47:40 am
« on: February 07, 2013, 10:47:40 am »
orange:
yellow:
green:
red:
grey:
Another green:
Mine is sort of black I think.
Any others?
Reply #1February 07, 2013, 04:24:15 pm
Re: block colors Just for fun.
« Reply #1 on: February 07, 2013, 04:24:15 pm »
There is a CAT themed MK1 rabbit somewhere on here.
EDIT: Urethra I found it
from this thread:
http://www.vwdiesel.net/forum/index.php?topic=18348.0
and the worse forum
http://forums.vwvortex.com/showthread.php?4896573-CAT-themed-TD-Rabbit
« Last Edit: February 07, 2013, 04:37:12 pm by theman53 »
Reply #2February 07, 2013, 04:33:04 pm
« Reply #2 on: February 07, 2013, 04:33:04 pm »
I wish I had the time.. and the garage space.. and another car to drive around :( I'd tear in to mine tonight if I had those prerequisites..
COOL THREAD! Moderator approved lol.
Reply #3February 07, 2013, 04:49:50 pm
« Reply #3 on: February 07, 2013, 04:49:50 pm »
That cat rabbit is so clean. A real chopper so to speak, nothing there that doesn't need to be. The battery must be in the back for balance.
Of course all of them are so clean.  8)
« Last Edit: February 07, 2013, 04:52:50 pm by scrounger »
Reply #4February 08, 2013, 05:33:33 am
CrazyAndy
  • 739
« Reply #4 on: February 08, 2013, 05:33:33 am »
My own block, done in Rust Bullet Black.
Black never goes out of style.  8)
And didn't the old 1.6s come light green from the factory?  I ask because my old block loks like it has some green paint under all that grime.
Reply #5February 08, 2013, 07:30:57 am
« Reply #5 on: February 08, 2013, 07:30:57 am »
The third picture down is approximately the same color as factory. It's like a John Deere green.
Reply #6February 08, 2013, 09:12:57 am
damac
  • 531
« Reply #6 on: February 08, 2013, 09:12:57 am »
I would like to do this and have had all my engines in pieces and on the stand to do so but I cannot bring myself to do it because of all the work it would take to degrease :(
I would love to hear tips on how the doityourselfer can do this at home?
I can't run a gas pressure washer where my projects are due to noise.  Is a pressure washer needed?  If so would an electric one work and are they noisy?
1985 turbo diesel jetta
Reply #7February 08, 2013, 10:50:16 am
CrazyAndy
  • 739
« Reply #7 on: February 08, 2013, 10:50:16 am »
Electric pressure washers are quieter by a moderate amount.  The gas PWs are better performing, but the electric ones are adequate for home projects.  Just douse your engine in de-greaser, let it sit for a while, and power wash.  Repeat until clean, and then wipe down with brake clean and lintless towels.  For paint prep, wipe an additional time with some alcohol.  Make sure to THOROUGHLY DRY ALL SURFACES; you don't want your deck or bores forming rust!
Reply #8February 08, 2013, 12:43:44 pm
« Reply #8 on: February 08, 2013, 12:43:44 pm »
1.5Ds were blue
1.6Ds were green..
Reply #9February 08, 2013, 03:50:27 pm
« Reply #9 on: February 08, 2013, 03:50:27 pm »
I wouldn't have guessed that the block color was std blue or green.
As far as noise I have a 6.5 hp briggs on my power washer. It isn't as loud as a lawn mower. Bigger muffler.
If you have a self serve car wash near by. Haul the block down there. They don't have great power.
You might be able to use some gunk degreaser then oven cleaner on the block.
Where do you live that you can't run lawn mower engine? I suppose there are no harleys owners near by.
Reply #10February 08, 2013, 07:28:35 pm
« Reply #10 on: February 08, 2013, 07:28:35 pm »
I only paint them after they have been tanked and bored over.  I like black.  I also liked the grey one.
Reply #11February 08, 2013, 08:54:40 pm
camboscams
  • 324
« Reply #11 on: February 08, 2013, 08:54:40 pm »
Lets not forget Detroit diesel Alpine green!
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #12February 08, 2013, 10:14:46 pm
rabbid79
  • 684
« Reply #12 on: February 08, 2013, 10:14:46 pm »
I dig that grey too.  Nice bridge between the aluminum head and the black brackets.
'15 WRX
Reply #13February 09, 2013, 01:13:50 pm
hillfolk'r
  • 1532
« Reply #13 on: February 09, 2013, 01:13:50 pm »
Love the detroit greens i think it looks close to factory green. A little tip to get he crusty rustys off your cast iron first. A hammer and chisel. Dont beat it like you wanna kill it and wear glassses and just with light taps you can get down to the base metal. Even a claw hammer using the claw end is helpful
Throttle cables ftw
Reply #14February 09, 2013, 01:19:59 pm
« Reply #14 on: February 09, 2013, 01:19:59 pm »
Alpine green is WAY more pale/greyish than the standard green..
grey shows oil leaks quite amazing btw..
black just looks too OEM, but DOES expel the most heat..
