Author Topic: AAZ k14 drain line help  (Read 5090 times)
February 03, 2013, 06:43:15 pm
bbob203
  • 1789
« on: February 03, 2013, 06:43:15 pm »
My drainline is toast went to summit they looked at me like an idiot. This one is available it off of a K03 i think. Im looking for suggestions to make this work on a k14.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1February 03, 2013, 07:06:17 pm
Re: AAZ k14 drain line help
« Reply #1 on: February 03, 2013, 07:06:17 pm »
Maybe a hydraulic shop can cut the flange and tube, put the flare and nut on it.
Reply #2February 03, 2013, 07:28:43 pm
bbob203
  • 1789
« Reply #2 on: February 03, 2013, 07:28:43 pm »
The straight pipe on mine is pretty dead too. Probably useable but i want it to last.
03 Jetta wagon TDi
Reply #3February 04, 2013, 05:32:28 am
stewardc
« Reply #3 on: February 04, 2013, 05:32:28 am »
If you can get the old one off, take it to a good hydraulic shop. A local shop did a great job on mine, though I did change the outlet fitting to this;
Reply #4February 04, 2013, 05:52:26 am
« Reply #4 on: February 04, 2013, 05:52:26 am »
I think he's going the other direction... there isn't a flange-boss on his turbo core, just the tapped hole for the straight pipe that leads to the compression fitting.
Reply #5February 04, 2013, 06:09:03 am
bbob203
  • 1789
« Reply #5 on: February 04, 2013, 06:09:03 am »
yea mine has no 2 bolt flange. Summit can't order me a new banjo eitger..
03 Jetta wagon TDi
Reply #6February 04, 2013, 06:22:24 am
« Reply #6 on: February 04, 2013, 06:22:24 am »
If you take the threaded end to a hose shop you could have a new one made. If you take the entire thing into a hose shop I guess would work better. They can copy it. If you wanted to make your own you could cut yours where the braided section attaches to the pipe part and double hose clamp an oil and temperature rated hose to it. Take you banjo off the braid and put it into the hose. You may have to weld a barb on the banjo or find a new banjo as I do not know how it might come off the braided part.
Reply #7February 04, 2013, 06:24:46 am
« Reply #7 on: February 04, 2013, 06:24:46 am »
I'd offer the one I have cheep, but I'm not sure it's any good either... got a big kink in the braid where somebody dropped it.
If yours is too destroyed to to take to a hydraulic shop, lemee know. I can probably take this one to the shop and get you a quote.
Reply #8February 04, 2013, 06:52:23 am
bbob203
  • 1789
« Reply #8 on: February 04, 2013, 06:52:23 am »
do you have the straight pipe part between turbo and braided too?
03 Jetta wagon TDi
Reply #9February 04, 2013, 07:18:19 am
« Reply #9 on: February 04, 2013, 07:18:19 am »
Yeah I have both, but I need to keep the straight section.
I can get you pix, dimensions, quotes, etc., if that helps.
Reply #10February 04, 2013, 09:40:50 am
81 vw pu
« Reply #10 on: February 04, 2013, 09:40:50 am »
This guy might have a used one.
http://www.qualitygermanautoparts.com/
He had the ecodiesel drainline when I put the aaz k14 on my 1.6.
Reply #11February 25, 2013, 06:11:34 am
bbob203
  • 1789
03 Jetta wagon TDi
