Author Topic: Always pay to check the discount rack at Summit.. Dakota digi content  (Read 4141 times)
February 03, 2013, 05:54:11 pm
bbob203
  • 1789
So i got one of these for $40
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=127/prd127.htm
I understand and has been mentioned before That I can use this to run my passat gas tach off the TDi crank sensor. Anyone have any info on how to set this up? I cant seem to find where it was mentioned before. Thanks
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1February 03, 2013, 06:02:16 pm
Re: Always pay to check the discount rack at Summit.. Dakota digi content
« Reply #1 on: February 03, 2013, 06:02:16 pm »
Pretty sure that will take it off the W terminal on the alternator as well..
Reply #2February 03, 2013, 06:08:56 pm
bbob203
  • 1789
« Reply #2 on: February 03, 2013, 06:08:56 pm »
It will but the crank sensor I feel will be more consitent and give a better reading. I really dont know though.
03 Jetta wagon TDi
Reply #3February 03, 2013, 06:10:41 pm
« Reply #3 on: February 03, 2013, 06:10:41 pm »
Might even be able to wire it up to the 3rd injector with the wiring on it.. Are you using an ALH? Do they even have this? AHU's do lol.
Reply #4February 03, 2013, 06:12:23 pm
bbob203
  • 1789
« Reply #4 on: February 03, 2013, 06:12:23 pm »
Nah using 1z. I bet it would work would just have to know its pulse count per injection maybe?
03 Jetta wagon TDi
Reply #5February 03, 2013, 06:14:24 pm
« Reply #5 on: February 03, 2013, 06:14:24 pm »
The 1Z should have it too, as electrically I think it was the same as the AHU.
Well it would measure #3's injection which only happens once per 2 crank revolutions right?
I dunnooo, either that or the crank should work well. I think the W on a serp belt would be accurate. No slippage on a serp belt.
Reply #6February 03, 2013, 06:15:25 pm
« Reply #6 on: February 03, 2013, 06:15:25 pm »
would be 1/4 rpm... aka fires 1time on 4 revolutions... picks up when fires.. all the tdi have 3 sensor till pd..
