Author Topic: Compression Test Results  (Read 13509 times)
January 18, 2013, 10:56:28 am
zolorin
  • 30
« on: January 18, 2013, 10:56:28 am »
So I finally got a bit fed up with the smoking start on my diesel pickup and finally decided to do a compression test
So here is what I have found once I pulled the injectors
#3 injector had a black body and did not have a ring that is indicative of it being properly seated against the steel insert.  I could not find the steel insert what so ever -- hmmm I guess this was first reason to be worry about a low compression worries.
I then tested all of the pistons with the diesel compression tool
1. 220 (retested at 210, same way that I did all 4 other, about 10 rotations)
2. 300
3. 290 (did not tested without the insert)
4. 310
I did the test cold (how much does doing it hot increases by? 40 psi, 50psi????)
So from what I am reading I am below the wear limit by a lot and number 1 is below the delta limit of 71 psi
So what else would you guys recommend to test before plunging into an engine rebuild?
1981 vw diesel rabbit pickup
(85 or 86 motor)
Reply #1January 18, 2013, 11:35:09 am
Re: Compression Test Results
« Reply #1 on: January 18, 2013, 11:35:09 am »
The compression reading isn't from a certain number of revolutions, but rather the reading when the needle stops moving up regardless of the number of revolutions.
Reply #2January 18, 2013, 11:40:46 am
zolorin
  • 30
« Reply #2 on: January 18, 2013, 11:40:46 am »
Agreed, I just did not have a helper who can tell me when the needle stop going up.  So I did one cylinder for trial to see how many revs did it stop rising and then added couple more.
The question is is the HG blown?
and should I be thinking of replacing pistons and rings??
(85 or 86 motor)
Reply #3January 18, 2013, 01:23:01 pm
  • 4553
« Reply #3 on: January 18, 2013, 01:23:01 pm »
Question on procedure.  Did you do it by pulling the injector and replacing it with the test tool?  I think that is what you did.  Correct if I am wrong.
Once you have these readings you could squirt about a tablespoon of oil in the top then place the adapter in the injector hole and try again.  If rings are the issue you normally will see an increase in pressure.  Try it and see what you get.  I have one cylinder that is bad and oil gives me 80-100 lbs more on a stone cold engine.
Isn't the normal 480 lbs per cylinder?  And wear limit some where about your best cylinder?  Bentley check.  Wow your hosed!!!
Bentley says this for my 81 1.6 NA:  Normal compression pressure is 398 to 483 psi.  If pressure for any cylinder is below the 398 psi limit or pressure is 71 psi different between any two cylinders the valves, rings, or cylinders may need replaced or bored out.
Time for a teardown and measurements to be taken I'd say.
Reply #4January 18, 2013, 01:24:52 pm
« Reply #4 on: January 18, 2013, 01:24:52 pm »
could be a blown headgasket causing #1 to be so low.  But the other 3 are really close together so you're going to need rings at a minimum, you'll have to check if the bores are within their wear limit and also if there is too much ovaling.  and you'll have to inspect the head while its off.  if you're lucky you can get away with just a hone, new rings, headgasket, headbolts rod bolts, and rod bearings.  but you'd have to be really lucky haha.
Reply #5January 18, 2013, 01:28:31 pm
  • 4553
« Reply #5 on: January 18, 2013, 01:28:31 pm »
Sounded like this thing still runs just smokes on start up.  Wait till he rebuilds it and he will have a thread that his starter won't turn it over anymore.  Or the battery is weak.  Buhaawwwaaa
Reply #6January 18, 2013, 01:45:04 pm
zolorin
  • 30
« Reply #6 on: January 18, 2013, 01:45:04 pm »
"starter will not turn" -- that is funny.
But yes it does/did run but smokes and has a low power (max speed is about 65 to 70 on a straightaway).
Yep pulled the injectors (all 4 of them), installed the tool/converter
So ya, I am hosed -- way low.
BTW who do you suggest for parts (and please don't say prothe)
(85 or 86 motor)
Reply #7January 18, 2013, 02:23:24 pm
« Reply #7 on: January 18, 2013, 02:23:24 pm »
Did you do the test with the engine at normal operating temp?  Does it have solid lifters?
Reply #8January 18, 2013, 02:30:26 pm
« Reply #8 on: January 18, 2013, 02:30:26 pm »
Be careful with that "wet test"... these engines run on oil.
As Andrew alludes, valves are not yet ruled out.
>270psi in each could still be a reasonable runner, if the engine starts and the blowby is managed to avoid runaway.
Reply #9January 18, 2013, 03:03:52 pm
« Reply #9 on: January 18, 2013, 03:03:52 pm »
If it isn't running away and you are just mildly upset about the smoke you could run it until you have a real problem. If it starts and runs it could keep going like this for anothe 100,000 miles. I would take the shot and find another block to rebuild in the meantime. That is me though. I just know the more you dig on these engines the more needs replaced and sometimes you could have done without it, sometimes not.
Reply #10January 18, 2013, 05:12:43 pm
  • 4553
« Reply #10 on: January 18, 2013, 05:12:43 pm »
I can't suggest many places for all your parts.  And if the valves are the problem you may not need many just some cleaning and polish about the inside.  I just picked up a set of Gotez (sp) rings for 80 off of Ebay.  Still haven't had time to get them in.  Like you I am smoking out the neighborhood instead of tearing it apart.  Oh, and checking the oil all the time.   :-[
Reply #11January 18, 2013, 09:07:51 pm
tyb525
  • 183
« Reply #11 on: January 18, 2013, 09:07:51 pm »
Have you checked your timing? I had mine a little too retarded when I first timed it and it smoked really bad when cold, but once warmed up it didn't smoke at all and ran fine.
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #12January 18, 2013, 09:25:59 pm
  • 4553
« Reply #12 on: January 18, 2013, 09:25:59 pm »
Normally smoke on start up can indicate poor timing, but with the numbers he has, he is in need of more than a few degrees of advancement.
Reply #13January 18, 2013, 09:37:30 pm
nwcali6
  • 69
« Reply #13 on: January 18, 2013, 09:37:30 pm »
Before settling in on the idea of a total rebuild rule out the head/valves.  Pulling the head will tell you a lot about the wear though.  Personally if I have to go with new rings, I'll change the pistons, and the mains.
  How many miles on the engine?  How tight is money?
Reply #14January 19, 2013, 08:26:40 am
« Reply #14 on: January 19, 2013, 08:26:40 am »
Before even considering pulling the head, make sure the valves are opening far enough.  Compression check should be done with the engine up to temp.
