Author Topic: advanced timing pros and cons  (Read 34075 times)
Reply #75April 01, 2013, 12:06:02 pm
Re: advanced timing pros and cons
« Reply #75 on: April 01, 2013, 12:06:02 pm »
Could it get better?  How many friends do you have on tap to push the car around town.   Mileage could be a record setter.  Forget that 100K VW that gets 261 MPG.  Got the 1980 or 90s version that never needs filling.
Reply #76April 01, 2013, 12:13:12 pm
« Reply #76 on: April 01, 2013, 12:13:12 pm »
My personal goal is to tweek all my rigs to 50mpg or better. (All have bested 50mpg excl. the Westy.)
I'm curious to know more about EGTs rising as a result from retarded injection timing*.
My butt-dyno is telling me I'm getting less nailing and more boost... possibly from hotter exhaust gasses, as the combustion starts later?
*At some point, timing could be so retarded that fuel is still burning as the exh. valve opens, but how about before then.
Reply #77April 01, 2013, 01:09:22 pm
Re: Re: advanced timing pros and cons
« Reply #77 on: April 01, 2013, 01:09:22 pm »
EGTs definitely rise with retarded timing, for exactly the reason you list - the more retarded the more combustion is still occurring at exhaust time.
Boost levels will be higher with timing retarded a bit, again for the same reason. Gasses still expanding as they enter the turbine = more force on the turbine = more boost pressure.
Sent from my HTC One X using Tapatalk 2
