Author Topic: advanced timing pros and cons  (Read 34051 times)
Reply #45January 10, 2013, 07:25:48 pm
Re: advanced timing pros and cons
« Reply #45 on: January 10, 2013, 07:25:48 pm »
Reply #46January 10, 2013, 07:32:05 pm
« Reply #46 on: January 10, 2013, 07:32:05 pm »
I timed my 88 1.6 TD to 0.040" and it was WAY too advanced to start cold.. I had to back the pump off like 1/4" in movement to come down to a suitable cold starting setting. I didn't put the gauge back in it, but its much lower than 0.040"
You must be dealing with some extremely worn engines  ???
Reply #47January 10, 2013, 07:34:20 pm
tyb525
  • 183
« Reply #47 on: January 10, 2013, 07:34:20 pm »
Well that would explain why I could hear an increase in clatter to a point, then disappear in higher rpms. Just like without the cold start, only more clatter in the lower rpms.
My cold start doesn't really increase idle speed though, but from what you all are saying, it should. I never heard anyone say that till now though. It never has since I've had the car. But it does "increase the clatter" and definitely helps at startup. So if it doesn't increase the idle, what does that mean?
« Last Edit: January 10, 2013, 07:36:12 pm by tyb525 »
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #48January 10, 2013, 07:36:16 pm
« Reply #48 on: January 10, 2013, 07:36:16 pm »
You may have a pump without the idle increase part. Is it the Early 80's Rabbit in your picture?? If so, that pump does not have an idle bump on the cold start lever.
Reply #49January 10, 2013, 07:39:02 pm
tyb525
  • 183
« Reply #49 on: January 10, 2013, 07:39:02 pm »
Yep '81 NA. So that would make sense then.
Reply #50January 10, 2013, 07:56:08 pm
« Reply #50 on: January 10, 2013, 07:56:08 pm »
1991 ECO block & head. Compression was 420psi across the row before I changed the HG a couple weeks ago... haven't done another compression test, yet.
Reply #51January 10, 2013, 07:57:13 pm
« Reply #51 on: January 10, 2013, 07:57:13 pm »
'Ay but what of the pump and injectors, compression doesn't have 'much' to do with injection.
0.053" is 1.3462mm! that is insanely high lol.
Reply #52January 10, 2013, 08:13:13 pm
« Reply #52 on: January 10, 2013, 08:13:13 pm »
Ja, .053" was a bit much, but it started after 3sec cranking and ran pretty well after warming. Back to .048" and starts easily.
I haven't checked break pressures & IP internal pressure. Just happy it starts easily and runs well.
Reply #53January 11, 2013, 07:40:11 am
bbob203
  • 1789
« Reply #53 on: January 11, 2013, 07:40:11 am »
so what effect does lower breaking pressute have one egt and on timing?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #54January 11, 2013, 08:24:21 am
« Reply #54 on: January 11, 2013, 08:24:21 am »
AIUI, lower break pressure will inject earlier, advancing timing for that injector.
(I have very little info on this engine, I pulled it, slapped a HG on it and stuffed it in to my 85. No pop-tests, no IP pressures. Runs a shade chuggy, but doesn't miss.)
Reply #55January 16, 2013, 07:27:53 am
bbob203
  • 1789
« Reply #55 on: January 16, 2013, 07:27:53 am »
looking like .045 timing is a touch to advanced for starting my engine below 30 degrees farenheit. On a warm day though it spins right off.
03 Jetta wagon TDi
Reply #56January 16, 2013, 09:58:07 am
« Reply #56 on: January 16, 2013, 09:58:07 am »
The TD? or TDI?
Reply #57January 16, 2013, 10:24:01 am
bbob203
  • 1789
« Reply #57 on: January 16, 2013, 10:24:01 am »
The TD? or TDI?
td. I wish the tdi was going still sitting in a pile in my Garage.
03 Jetta wagon TDi
Reply #58January 16, 2013, 12:12:33 pm
« Reply #58 on: January 16, 2013, 12:12:33 pm »
WHA?!
TOO MUCH timing to start cold?!
my engine starts great when its cold.. the more timing, the merrier..
isnt it TOO RETARDED of timing that messes shizz up?
Reply #59January 16, 2013, 12:21:34 pm
bbob203
  • 1789
« Reply #59 on: January 16, 2013, 12:21:34 pm »
Maybe my compression sucks  :'(
03 Jetta wagon TDi
