Author Topic: What to do: 60k mile Eco D engine sat for 14 years when car was wrecked  (Read 15944 times)
Reply #45August 29, 2013, 04:19:49 pm
  • 5104
Re: What to do: 60k mile Eco D engine sat for 14 years when car was wrecked
« Reply #45 on: August 29, 2013, 04:19:49 pm »
I bought a pump off ebay that wasnt full of anything or sealed up, i let it sit basically emptyfor 2-3 years and then put it on my car and its been on there for a few years now too haha
Reply #46August 29, 2013, 04:24:03 pm
« Reply #46 on: August 29, 2013, 04:24:03 pm »
You got extremely lucky the seals didn't shrivel and leak. lol
Reply #47August 29, 2013, 05:33:56 pm
92EcoDiesel Jetta
« Reply #47 on: August 29, 2013, 05:33:56 pm »
Is that what usually happens to a pump that sat for a long time? Maybe it has something to do with the low mileage (60k) and that it was full of fuel?
Reply #48August 29, 2013, 05:54:51 pm
« Reply #48 on: August 29, 2013, 05:54:51 pm »
If the seals are original they will need replacing very shortly now that you are running them trough ULSD.
Reply #49August 29, 2013, 07:46:51 pm
92EcoDiesel Jetta
« Reply #49 on: August 29, 2013, 07:46:51 pm »
Why 2 cycle oil? High sulfur diesel was in there for 14 years and the IP is fine.  Does low sulfur diesel go rancid faster?
Reply #50August 29, 2013, 08:28:39 pm
  • 4553
« Reply #50 on: August 29, 2013, 08:28:39 pm »
I think the ULSD does go bad sooner.  The sulfur would act as a preservative or at least like an anti bacterial agent.
Reply #51August 30, 2013, 02:26:09 am
« Reply #51 on: August 30, 2013, 02:26:09 am »
It's worse than that, sulphur diesel conditioned the seals in a certain way that kept them swelled up, and the super low aromatic content of ULSD pulls that conditioning out causing the seals to shrink and crack.  it's not that ULSD makes it leak, it is the act of switching.
Reply #52August 30, 2013, 06:23:21 am
92EcoDiesel Jetta
« Reply #52 on: August 30, 2013, 06:23:21 am »
How else would you observe them while running it, if he was not in fact meaning external? Lol.
Could be an oil one too, it'd be hard to see with water squirting all over.
 Revisiting this one, external head gasket coolant leaks can be easily found with a pressure test.
Reply #53August 30, 2013, 06:42:50 am
92EcoDiesel Jetta
« Reply #53 on: August 30, 2013, 06:42:50 am »
I was surprised at how quiet the engine was with no muffler or resonator, just the turbo mounted to the exhaust manifold.
 I really think this engine has only 60k miles. The engine sounds great. No play on the intermediate shaft. The OE clear nylon fuel lines are completely clear.
 click to play if you haven't heard it already
« Last Edit: August 30, 2013, 07:39:17 am by 92EcoDiesel Jetta »
Reply #54August 31, 2013, 09:49:51 am
92EcoDiesel Jetta
« Reply #54 on: August 31, 2013, 09:49:51 am »
[quote author=92EcoDiesel Jetta .............
I had a hell of a time priming the injection pump. The injector hard lines were off on the first  attempt and no matter what I tried could not get the IP to suck fuel. I tried using a Mityvac on the return barb to fill the IP, then tried filling it with a funnel via the return banjo pedestal, but cranking the engine would not suck fuel from the fuel bottle into the IP, and only the the 2 lower delivery valves had fuel squirting out of them (one squirted a little more than the other), the other 2 delivery valves had nothing coming out of them. I thought the IP or transfer pump was gunked up from sitting for 14 years or the pump has a leak and needs resealing. I was ready to pull the pump then said to myself it's worth a try putting the injector hard lines on for another attempt. It's not that much more work and will save me from pulling the IP (and opening a can of worms) if it works.
It worked!
[/quote]
 Any comments as to why I could not get the IP primed and suck fuel with the injector hardlines off?  And why only the lower two delivery valves were squirting out fuel? It was only after I installed the injector hardlines that it primed easily and ran.
 I remember reading about someone else with a similar problem recently.
Reply #55September 03, 2013, 01:46:18 pm
92EcoDiesel Jetta
« Reply #55 on: September 03, 2013, 01:46:18 pm »
Just from running the engine for approx 2 to 3 minutes brought the cold compression reading of cyl #1 from 309 psi to 420 psi.
Reply #56September 03, 2013, 01:50:31 pm
92EcoDiesel Jetta
« Reply #56 on: September 03, 2013, 01:50:31 pm »
I mixed in some 2 stroke oil into the bottle ran it for 30 seconds, capped the IP in/out, drained the water and filled it with antifreeze and capped the ports, put engine at TDC, ready for storage.
CLICK TO PLAY!
Reply #57September 20, 2013, 10:04:22 pm
Toby
  • 728
« Reply #57 on: September 20, 2013, 10:04:22 pm »
FWIW don't worry about the compression at this point. The compression will almost certainly come up and level out after it has run a while. I have probably brought a hundred vehicles back to life after they were abandoned by someone else and they "need to get used to runnin" again" as the old guys used to say.
Reply #58September 21, 2013, 07:59:32 am
« Reply #58 on: September 21, 2013, 07:59:32 am »
Had that a few times too Toby.
