Author Topic: 1986 Golf 1.6 N/A Crank No Start  (Read 65150 times)
Reply #210March 24, 2015, 08:29:19 am
jhax
  • 328
Re: 1986 Golf 1.6 N/A Crank No Start
« Reply #210 on: March 24, 2015, 08:29:19 am »
Thanks for the suggestions fellas, but what would I ground to where and why? Engine to body? Alternator to engine? I currently am not having any ground issues at this point.
Justin
Reply #211March 24, 2015, 08:40:41 am
air-cooled or diesel
« Reply #211 on: March 24, 2015, 08:40:41 am »
i ran grounds from main trans ground to top of alt and from top of alt to body, as trans to body grnd tends to go first.
Reply #212March 24, 2015, 09:06:16 am
jhax
  • 328
« Reply #212 on: March 24, 2015, 09:06:16 am »
Ah, I understand, I actually updated all of my grounds when I did my semi wire hide, battery relocation. I have some welding cable going from my - battery post to the bolt that holds the rear bumper on and another cable from the lateral bolt that holds the front bumper to the body to the bellhousing.
Reply #213March 25, 2015, 05:57:09 pm
« Reply #213 on: March 25, 2015, 05:57:09 pm »
the main thing is to have the ground to engine/trans housing for glow plugs and starts/cold st. and a ground or 2 from motor to body. i ran a ground from trans tunnel to alt top, then another from alt top to body. it seems vw used 2 smaller ground wires to ground body to battery term. not 1 big wire.--that would be 1 connection, you indicate you have 2 body grounds, 2 smaller wires with separate connectors for each body ground. makes current able to flow more smoothly. as current is choosy and can get an attitude!
