Author Topic: 1986 Golf 1.6 N/A Crank No Start  (Read 65446 times)
Reply #195February 16, 2015, 07:39:41 pm
jhax
  • 328
Re: 1986 Golf 1.6 N/A Crank No Start
« Reply #195 on: February 16, 2015, 07:39:41 pm »
Well, it died sooner than later. Experiencing some harder starts lately. I think I need a new turn buckle too, I have no Idea how this belt is continually loosening but it's happening and I am not amused. Ordered the bosch reman from autohausaz today. Good news though, got the ol' tax return. Time to get the ALH head ported and polished with some new 80mm titanium valves.
Justin
Reply #196February 28, 2015, 04:46:45 pm
jhax
  • 328
« Reply #196 on: February 28, 2015, 04:46:45 pm »
Alrighty, I am having issues snapping bolts that hold the alternator to the bracket. When I first deleted AC I just swung the alternator down and used a turn buckle as a tensioner. I believe that was one of the issues with going through alternators, they were slightly cocked from the tension placed on it by the belt, screwing up the bearings and snapping the through bolt that held the alternator to the bracket. I then rotated the alternator 180* and bolted it to the bracket using the bolt hole that is traditionally used for the tensioner bolt.
I purchased a 38 1/8" belt so it wouldnt slap around while running. After putting it on I didnt need a tensioner (turnbuckle) but now I am snapping bolts again. I bought a 38 5/8" belt today in hopes of preventing overtensioning the belt and causing the bolts to snap but it's too loose. What have you guys done? I do have a non AC alternator bracket, however I cannot get my existing bracket off due to a bolt that is tucked underneath the IP. Is there a way to get that bolt out without having to take the pump off?
Thanks,
Justin
Reply #197February 28, 2015, 05:20:05 pm
« Reply #197 on: February 28, 2015, 05:20:05 pm »
It's a b*tch if it hasn't been removed for some time. I used an "S" wrench, but it wasn't pretty using a pry bar to turn it.
FWIW, I kept my compressor, because it works well enough as a relay pulley.  I don't need to retighten that often, and a new belt every 18-24 mo. ain't that bad.
Reply #198February 28, 2015, 06:18:53 pm
jhax
  • 328
« Reply #198 on: February 28, 2015, 06:18:53 pm »
Ah, my condenser is already off and out and my alternator is already in place with the correct pulley. My issue is the pivot bolt that holds the alternator onto the bracket keeps snapping due to the tension of the belt (I assume).
Reply #199February 28, 2015, 06:59:36 pm
srgtlord
  • 797
« Reply #199 on: February 28, 2015, 06:59:36 pm »
Time for a serpentine setup ;)
Reply #200February 28, 2015, 07:19:01 pm
jhax
  • 328
« Reply #200 on: February 28, 2015, 07:19:01 pm »
Yeah I just dropped a few dollars on a new alternator I guess a grade  12.9 bolt will have to do. Now just to find one of proper length and pitch.
Reply #201March 02, 2015, 07:22:15 pm
jhax
  • 328
« Reply #201 on: March 02, 2015, 07:22:15 pm »
Welp, think I found the correct combination. 993 mm belt with a 120mm grade 12.9 grade socket cap Bolt without grinding the original bracket at all. 14.3 V at the battery in the hatch, never seen that before. We shall see.
« Last Edit: March 02, 2015, 08:21:07 pm by jhax »
Reply #202March 02, 2015, 07:31:01 pm
« Reply #202 on: March 02, 2015, 07:31:01 pm »
A picture, if you get a chance? Thx.
Reply #203March 02, 2015, 08:20:22 pm
jhax
  • 328
« Reply #203 on: March 02, 2015, 08:20:22 pm »
Reply #204March 03, 2015, 04:44:28 am
« Reply #204 on: March 03, 2015, 04:44:28 am »
OK, got it, thanks.
OT: Radiator fan? Bleed hose?
Reply #205March 03, 2015, 12:36:45 pm
jhax
  • 328
« Reply #205 on: March 03, 2015, 12:36:45 pm »
Pusher fan and what's a bleeder hose?
Reply #206March 03, 2015, 12:57:47 pm
« Reply #206 on: March 03, 2015, 12:57:47 pm »
Air bleed/purge hose: the tube on the radiator or upper hose to the reservoir.
Reply #207March 03, 2015, 04:49:01 pm
jhax
  • 328
« Reply #207 on: March 03, 2015, 04:49:01 pm »
Top fill radiator from a MK1 or Scirocco
Reply #208March 20, 2015, 10:57:28 pm
  • 2932
« Reply #208 on: March 20, 2015, 10:57:28 pm »
Hey, I see you have some extra pivot bolt sticking out there.
 I suggest you double nut it. I had to on one of mine because it kept vibrating out.
 Keep an eye on it.
Reply #209March 22, 2015, 04:43:06 pm
air-cooled or diesel
« Reply #209 on: March 22, 2015, 04:43:06 pm »
that bolt sticking out of what looks like the top of the alt; perfect for additional grounding w/a nut, etc.
