Author Topic: WTB passat AAZ un cut engine wiring harness  (Read 3585 times)
January 03, 2013, 05:12:48 pm
bbob203
  • 1789
« on: January 03, 2013, 05:12:48 pm »
Looking for one for my mtdi swap to keep things tidy and smooth. Let me know what you have.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1January 03, 2013, 08:39:13 pm
Re: WTB passat AAZ un cut engine wiring harness
« Reply #1 on: January 03, 2013, 08:39:13 pm »
searosly  too much work... power wire on coil to pump...
temp/pressure sensors same...
starter same
will need to add w wire for tach..
glow plugs..... i have thought to try on this... i think if energized while cranking life perfect... most it would be on cold day is like 10 sec... i have yet to need them.. 8v starting under 0f with none...
Reply #2January 04, 2013, 09:56:21 am
« Reply #2 on: January 04, 2013, 09:56:21 am »
Yup, starts with some work.. but it started.
With 5 second glow at the same temps it fires in a crank and a half.
