Author Topic: 1.6 TD no-run, I need a few minds on this one..  (Read 13374 times)
Reply #15December 31, 2012, 08:08:07 pm
Re: 1.6 TD no-run, I need a few minds on this one..
« Reply #15 on: December 31, 2012, 08:08:07 pm »
Stock TD, pump lid had a bum throttle bushing when i went to buy it. Swapped lids in the guys driveway and drove it home. That was in August, finally got around to fixing it lol. It is a full TD pump now again.
Reply #16December 31, 2012, 09:07:07 pm
« Reply #16 on: December 31, 2012, 09:07:07 pm »
Its a one hole pulley, and no even if it were a 2 hole I know the pump shaft key-way needs to point roughly at 11 o'clock when looking at the snout
... when the cam lobes are both pointing UP for the number one cylinder or the cam lock is in.  I'm just looking for confirmation that you referenced the cam with the pump.
Reply #17December 31, 2012, 09:09:05 pm
« Reply #17 on: December 31, 2012, 09:09:05 pm »
This is a hurtful comment, LMAO! Could I really be so stupid? I ALWAYS set the engine to TDC before I remove the pump.
Yes the cam and pump locks were used. It all remained in time after several revolutions. ;)
Reply #18December 31, 2012, 09:16:08 pm
« Reply #18 on: December 31, 2012, 09:16:08 pm »
It's not meant to be hurtful.  Sometimes we all have 'doh' moments.
« Last Edit: December 31, 2012, 09:21:03 pm by 8v-of-fury »
Reply #19December 31, 2012, 09:17:49 pm
« Reply #19 on: December 31, 2012, 09:17:49 pm »
 ;D
Reply #20December 31, 2012, 09:21:11 pm
« Reply #20 on: December 31, 2012, 09:21:11 pm »
The LMFAO, was cheek in tongue sarcasm haha. I have checked and thought over everything.
As you say if I am getting fuel to all four injectors there is nothing much else it could be.
Reply #21December 31, 2012, 09:23:53 pm
rallydiesel
  • 1880
« Reply #21 on: December 31, 2012, 09:23:53 pm »
Next step for me would be a tow start.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #22December 31, 2012, 09:26:32 pm
« Reply #22 on: December 31, 2012, 09:26:32 pm »
Extremely hard for me to do for two reasons, my neighbours are stuck up old rich ***'s, and the roads are all hard packed snow I dunno if it will work or just slide when you try to drop the clutch.. or if the two vehicle will get traction eh?
Reply #23December 31, 2012, 09:33:05 pm
rallydiesel
  • 1880
« Reply #23 on: December 31, 2012, 09:33:05 pm »
Yeah that makes it harder. A nice aggressive tow-start is my BFH.
Reply #24January 01, 2013, 08:33:31 am
« Reply #24 on: January 01, 2013, 08:33:31 am »
I've never had to tow-start one of these.  I've always just fixed the problem that is preventing it from starting.  Try turning the max fuel screw in one full turn but be ready to shut it down quick if it races.
Reply #25January 01, 2013, 09:25:06 am
« Reply #25 on: January 01, 2013, 09:25:06 am »
I thought about doing that, but then i thought.. This pump lid ran the engine before as well and marked throttle linkage and always count turns out for max fuel screw. Plus its still got the collar on it. So its at stock right now if it were close flooring it should do it no??
Reply #26January 01, 2013, 12:38:37 pm
« Reply #26 on: January 01, 2013, 12:38:37 pm »
Hence the Rookie/Newbie share thread.  I tend to get that way if I am pushing it all day long and don't break for lunch or coffee.  Brain just reverts to I Don't Know mode, or limp mode and I end up doing duh?  stuff I laugh at the next day.
Reply #27January 01, 2013, 01:57:41 pm
rallydiesel
  • 1880
« Reply #27 on: January 01, 2013, 01:57:41 pm »
Yeah but he doesn't know what the problem is. At least if he gets it started then he can get a better idea of what the issue is by how it runs.
Reply #28January 01, 2013, 05:39:53 pm
srgtlord
  • 797
« Reply #28 on: January 01, 2013, 05:39:53 pm »
Im going to guess low compression
Reply #29January 01, 2013, 07:06:20 pm
« Reply #29 on: January 01, 2013, 07:06:20 pm »
If I understand correctly, this was a TD pump with a NA cover on it, you resealed it and installed the original TD top cover that now has a new throttle shaft bushing?
Assuming that is correct, did you ever hear the car run with the original TD top?
I'd be winding the fuel screw in and taking it from there, or pull starting it. It'll be tricky in the snow but assuming you are on winters and not all seasons you should be fine.
Try running 12v from the battery to the stop solenoid. Sometimes these crazy cars forget to send power to the stop solenoid when you are cranking.
