Author Topic: 2.5 l5 Audi AEL spool with hx25?  (Read 4027 times)
December 27, 2012, 10:27:59 pm
A.Dutsov
« on: December 27, 2012, 10:27:59 pm »
I am thinking to compound hx25 and hx35 i have for an AEL 140hp 2.5 engine, but i dont want to early spool up, how do you think the hx25 will spool? i cant find many specs on this turbo from internet, but i think its similar to TD04HL-13T:
exhaust wheel
outside diameter, inducer 52mm
exducer 45.6mm
tip width 8.9mm
compressor wheel
inducer 40.64mm
big diameter 56mm
tip width 4.98
exhaust housing 8.5cm2
i think the holset have smaller exhaust hausing, and a little bigger compressor inducer with anty surge ... but its pretty similar turbo ...
so i need it to spool around 1500 and then spool the hy35 or hx35 i have both, with 9, 12, 14 and 16cm housings, so i can match them ... till lets say 5000 rpm, i dont have power goal, i want to make as much as possible, without blowing the engine, and keep it stock internals for now. i will use external wastegates for both turbos, the first one with spring only, with 1.5 bar setting, and the second one i think to use my ex racecar greddy profec b boost controller, as i can smooth the boost if i need to, and i can better controll it. What do you think, how will this theoretically work?
Reply #1December 29, 2012, 03:00:25 pm
Re: 2.5 l5 Audi AEL spool with hx25?
« Reply #1 on: December 29, 2012, 03:00:25 pm »
All I can say is that I think hx25 would spoil fast especially in compound
Reply #2December 29, 2012, 03:17:26 pm
« Reply #2 on: December 29, 2012, 03:17:26 pm »
The 4BT guys seem to consider it all done by 200HP.
