Author Topic: 1,6TD engine bits and 1Z TDI part out  (Read 4325 times)
December 20, 2012, 01:42:47 pm
« on: December 20, 2012, 01:42:47 pm »
1.6TD parts
Breather tube - $10 SOLD
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0034-1.jpg
Valve Cover - $10 SOLD
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0033-1.jpg
Downpipe - $40
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0032-1.jpg
Injection lines - $40
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0031-1.jpg
Un-lipped IM pulley - $10
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0030-1.jpg
IM shaft and retainer - $10
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0029-2.jpg
Oil filter flange and tube for oil cooler - $25
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0028-1.jpg
Air box - $20 SOLD
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0026-1.jpg
Non AC alternator and Pulleys (need to test alternator next time I'm in town) $50 SOLD
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0025-3.jpg
1.6TD head. Belt broke, lifter bore #1 needs the edges filed/machined down. A lifter will not slide in it. All other lifter bores are fine. Valves should be replaced. No lifters. Cam included. $40 SOLD
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0017-1.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0018-3.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0019-3.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0021-2.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0022-3.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0023-3.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0024-2.jpg
TDI Bits 1997 Passat, 430 000kms on body, unknown on engine (replaced a year ago). Ran very well. Only codes were:
00560 - Exhaust Gas Recirculation System
            17-10 - Control Difference - Intermittent
01050 - Glow Plug Monitoring
            35-10 -  -  - Intermittent
Engine wiring harness and most (if not all) the vacuum pieces - $100
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0043-1.jpg
Fuse block w/ relays and fuses - $50
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0042-1.jpg
ECU - $100
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0041-1.jpg
Interior wiring harness - I wasn't getting power to the OBDII port. I had to jump it to get the codes. Either a fuse or broken wire to switched power - $75
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0040-1.jpg
Pedals - $75
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0039-1.jpg
Air box w/ MAF - $50
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0038-1.jpg
Engine - I'm parting it out, just haven't taken it apart yet. Make offers on whatever. Alt, AC and starter are sold.
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0045-1.jpg
I'm open to offers on all this stuff. I'd like to see it move before I head out.
« Last Edit: December 24, 2012, 07:08:44 pm by burn_your_money »
Reply #1December 20, 2012, 05:52:00 pm
Blocksmith
  • 261
    Wrench Lurker
Re: 1,6TD engine bits and 1Z TDI part out
« Reply #1 on: December 20, 2012, 05:52:00 pm »
PM sent.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #2December 21, 2012, 10:10:48 am
EphinEll
  • 3
« Reply #2 on: December 21, 2012, 10:10:48 am »
PM'd
