02a starter
Topic: 02a starter (Read 3372 times)
December 18, 2012, 01:11:41 pm
rodpaslow
02a starter
December 18, 2012, 01:11:41 pm »
I know this may not be the place to put this. I plan on changing to an 02A tranny, if someone has a 02a 4 cyl. starter for this laying around, can you give me a rough distance from the mounting that it would mount to on the transmission with, to the end of the gear?
I bought a pricey starter $400 or so, and I want to see if there is anyway I can use it once changed to an 02A.
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
December 18, 2012, 06:52:42 pm
rabbit_tdi
Newbie
Re: 02a starter
December 18, 2012, 06:52:42 pm »
It so happens I have one here at my desk. :-) From the flange to the end of the shaft is 2.7 inches. From the flange to the end of the gear is 1.3 inches.
1984 Rabbit to be TDI
1982 Rabbit turbo diesel
December 19, 2012, 07:51:51 am
rodpaslow
Re: 02a starter
December 19, 2012, 07:51:51 am »
Thanks!
December 19, 2012, 08:46:54 am
Re: 02a starter
December 19, 2012, 08:46:54 am »
o2a vs o2o will not swap.. teeth on flywheel not same...
December 19, 2012, 10:00:53 am
rodpaslow
Re: 02a starter
December 19, 2012, 10:00:53 am »
Not good, I guess that theory is out the window. I'll have to sell it, or trade it I guess.....
December 20, 2012, 08:04:55 am
rodpaslow
Re: 02a starter
December 20, 2012, 08:04:55 am »
I looked over the starter again - does the 02a starter use 10 teeth for the gear? I know the auto tdi (2000-2005? - SR 34X) starter in my other car works with the pressure-plate to crank, flywheel to pressure plate of the 020.
This starter just has a snap ring and spline to hole onto the gear. If it's a 10 or 8 tooth gear I can maybe change it?
December 20, 2012, 12:21:51 pm
Re: 02a starter
December 20, 2012, 12:21:51 pm »
dude... simple.. if it was that easy... vw would not have changed it... hell they wet thru all the work to make ewer autos use the old 020 starter... why when 02a came out same year... its differet... hell old 02a starter like a 020 w/bushing... newer 02a goto a supported end...
December 20, 2012, 02:11:50 pm
Re: 02a starter
December 20, 2012, 02:11:50 pm »
Auto TDI starters will work for the 020 trans iirc from my adventures. But the manual TDI starter is 02A specific.
December 20, 2012, 04:30:28 pm
Re: 02a starter
December 20, 2012, 04:30:28 pm »
While we aren't on the subject, does anyone know what starter will work with my 096? Any way to tell short of just hooking it up and trying it?
December 30, 2012, 11:15:14 pm
mzak88
User+
Re: 02a starter
December 30, 2012, 11:15:14 pm »
Totally different. Solenoids will interchange, however...
97 IDI Jetta, O2A CTN,0.658 5th, 1.6 boost pin, TDI IC, 2.0 brakes, some tuning.
02a starter
