Author Topic: WTB 1986 Jetta dash board. Blue  (Read 5549 times)
December 15, 2012, 05:15:44 pm
« on: December 15, 2012, 05:15:44 pm »
Let me know what you have. Mine has a 100 cracks in it.
thanks.
Reply #1December 15, 2012, 07:24:18 pm
bbob203
  • 1789
Re: WTB 1986 Jetta dash board. Blue
« Reply #1 on: December 15, 2012, 07:24:18 pm »
I might be able to help you out. Wrenching on a potentially dead motor mk2 golf tomorrow. If it doesn't go well the dash is yours.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2December 15, 2012, 07:25:45 pm
« Reply #2 on: December 15, 2012, 07:25:45 pm »
sweet!
Reply #3December 16, 2012, 07:50:47 am
« Reply #3 on: December 16, 2012, 07:50:47 am »
Here is my Jettas dashboard.
« Last Edit: December 16, 2012, 07:52:32 am by scrounger »
Reply #4December 16, 2012, 02:14:20 pm
Big Daddy Roth
  • 298
« Reply #4 on: December 16, 2012, 02:14:20 pm »
Where were you two weeks ago? I just tossed one out.
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #5December 16, 2012, 02:50:00 pm
rs899
  • 647
« Reply #5 on: December 16, 2012, 02:50:00 pm »
Mine is far worse than that picture.  Resembles the Grand Canyon.
I think the further south you go the worse they are.
« Last Edit: December 18, 2012, 08:49:27 am by rs899 »
Reply #6December 17, 2012, 10:49:01 am
« Reply #6 on: December 17, 2012, 10:49:01 am »
had a PRISTENE one a month ago.. wish i would have known.
Reply #7December 17, 2012, 10:50:35 am
« Reply #7 on: December 17, 2012, 10:50:35 am »
BTW, be sure to get a GERMAN dash..
the american and mexican dashes are ever soo slightly different..
you will need some new brackets and trim pieces..
Reply #8December 17, 2012, 06:29:37 pm
« Reply #8 on: December 17, 2012, 06:29:37 pm »
Hi
I assumed that all of the mk 2 jetta golfs in the US were German made. You are right I want it plug and play.
Reply #9December 17, 2012, 06:48:41 pm
« Reply #9 on: December 17, 2012, 06:48:41 pm »
Not all. Wolfsburg were German for sure. Also, IIRC golfs and jettas don't mix well.
Reply #10December 17, 2012, 06:52:40 pm
« Reply #10 on: December 17, 2012, 06:52:40 pm »
mine is a wolfy, but produced in america, with an american dash/interior..
ive had all 3 kinds of cars (german, american, and mexican) and all of them have slightly different dashes..
the vents and defrosters mount differently, and none of the sh*t is the same..
Reply #11December 17, 2012, 07:03:37 pm
« Reply #11 on: December 17, 2012, 07:03:37 pm »
Where would I check to fine out the details.  The SN?
Reply #12December 17, 2012, 08:26:02 pm
« Reply #12 on: December 17, 2012, 08:26:02 pm »
well i disagree.. 2 dashes...
1st is westy built 85-88 golfs... the easiest way to tell... the piece aroud speedo... westy the dash holds the 4way/defog vs that plastic.. this makes heater controld, fuse box mouting, center cosol, vents differet...
rest of them... plastic aroud speedo/radio also holds the 4way/defog... ce1-ce2 wirig, controls same, so on..
now in 88 the dash plastic, material got a little more rouded, and the trim switched up but its majority of dash pieces are "rest of them" in the way it fits... but some 88 are westy.. so be careful...
next blue/brown dashes were 85/86 type of thig... by 88 its black... unless you got a odd color combo.. say a 88 carot jetta with the brown recaros... only seen 1 set.. and that car was nice... and was purchesed new by its owner.. so some odd option..
Reply #13December 18, 2012, 04:14:36 am
« Reply #13 on: December 18, 2012, 04:14:36 am »
Hi MP5
By westy you mean West German?
On my german made 1986 Jetta,
 the heater control is bolted in from behind the
dash and the dash is actually clamped in between the vacuum control and the plastic trim.
The center console fits into a grommet in the dash   Never had the dash out of the car so I can't speak to some of the other aspects.
Reply #14December 18, 2012, 05:52:19 am
« Reply #14 on: December 18, 2012, 05:52:19 am »
Pretty sure he means Westmoreland PA
