Author Topic: FS Mostly AAZ parts, 1.6TD pump  (Read 5089 times)
December 11, 2012, 04:34:46 pm
« on: December 11, 2012, 04:34:46 pm »
It's time to clear out the shop for winter. Will ship anywhere. Please include item number with any questions
1) AAZ Intake Manifold $60 SOLD
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0007-2.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0006-3.jpg
2) 1.6TD pump - unknown KMs, unknown condition (told it ran fine) $120
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0008-2.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0010-2.jpg
3) K03 Turbo - about 1-2mm of in and out play and about the same up and down. Oil line not included - $75 SOLD
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0011-2.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0012-1.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0013-1.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0014-1.jpg
4) K03 intake hoses $10 each
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0015-1.jpg
5) AAZ Valve cover with hoses - $20
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0016-1.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0017.jpg
6) 1.6  TD cam baffle - $5
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0018-1.jpg
7) AAZ EGR pipe $10
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0019-1.jpg
8) AAZ K03 turbo manifold w/ EGR (good for external wastegate?) - $40 SOLD
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0020-1.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0021-1.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0022-1.jpg
9) 1.6TD exhaust manifold (K24, T3, T2, K14) - $30 SOLD
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0023-1.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0025-1.jpg
10) AAZ intake w/ EGR $40
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0027-1.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0028.jpg
11) AAZ head #1 - Precup #1 looks to be installed on an incorrect angle. Glowplug hole #3 is crossthreaded/on an angle so the glowplug is not seating correctly. It can probably be fixed with the correct tap (which I don't own). It is sealing as is and was running. $30
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0029.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0032.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0033.jpg
12) AAZ Head #2 - Exhaust valve #1 bent and lifter is dead. Lifter bore is fine. Other valves might be tweaked as well, they weren't sealing very well but may just need to be lapped. Only 1 crack between valves. No cracks in precups. Glowplug holes #3 and #4 are crossthreaded/on an angle so the glowplug is not seating properly. It is sealing as is and was running. Cam doesn't look the greatest.  $75
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0034.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0037.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0036.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0038.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0039.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0040.jpg
http://img.photobucket.com/albums/v603/burnyourmoney/IMG_0041.jpg
« Last Edit: December 24, 2012, 07:24:02 pm by burn_your_money »
Reply #1December 14, 2012, 09:30:15 pm
sprstu
  • 99
Re: FS Mostly AAZ parts, 1.6TD pump
« Reply #1 on: December 14, 2012, 09:30:15 pm »
Damn, just a couple days late on the turbo and mani. I would love to pick up a top-mount K03 or K14 from an AAZ.
Mk1 caddy TD, mk4 Golf Tdi
Reply #2December 15, 2012, 05:48:55 pm
« Reply #2 on: December 15, 2012, 05:48:55 pm »
U got a vane style vacuum pump?
Reply #3December 15, 2012, 06:51:11 pm
« Reply #3 on: December 15, 2012, 06:51:11 pm »
Reply #4December 24, 2012, 07:24:16 pm
« Reply #4 on: December 24, 2012, 07:24:16 pm »
Updated prices on AAZ heads.
