Author Topic: slow cranking after glowplug replacement?  (Read 5056 times)
December 10, 2012, 03:40:04 pm
Paul604
  • 9
« on: December 10, 2012, 03:40:04 pm »
I have a 1997 jetta 1.9 td finally got around to replacing all 4 glowplugs, got it all back together, went to start it up and i get a slow crank now, gauges bouce around, clock reset on the dash, sometimes the alarm even goes off. Could it just be a bad battery? ive only had 2 glowplugs working for the last year maybe doing all 4 new ones is enough draw to expose a bad battery? Even jump starting it doesnt work though so im really not sure what happened here. Should the glowplug bus bar be grounded when hooked up? it seems to be, its not touching anything though besides the glowplugs. Not really sure what to do here.
Reply #1December 10, 2012, 03:54:56 pm
Re: slow cranking after glowplug replacement?
« Reply #1 on: December 10, 2012, 03:54:56 pm »
I'd check all the ground connections between motor and frame, plus frame and battery neg. I'd also check battery positive connector.
Reply #2December 10, 2012, 04:48:17 pm
« Reply #2 on: December 10, 2012, 04:48:17 pm »
Yep weak battery or connectors. You are drawing a lot more electricity before you engage the starter. Like Tyler said do the cheap stuff first.
Reply #3December 10, 2012, 04:51:33 pm
« Reply #3 on: December 10, 2012, 04:51:33 pm »
Since your starter doesn't work with a jump it is the cable connections. Just to confirm Tylers Dx.
Reply #4December 10, 2012, 04:59:47 pm
Paul604
  • 9
« Reply #4 on: December 10, 2012, 04:59:47 pm »
Checked all the battery connections, all seem good. Pulled the battery out, going to get it load tested. Sure hope thats all it is.
Reply #5December 10, 2012, 05:01:02 pm
Paul604
  • 9
« Reply #5 on: December 10, 2012, 05:01:02 pm »
Is there any ground connections that normally go bad? I just checked the main one from the battery to the block
« Last Edit: December 10, 2012, 05:03:16 pm by Paul604 »
Reply #6December 10, 2012, 05:19:05 pm
Paul604
  • 9
« Reply #6 on: December 10, 2012, 05:19:05 pm »
well had the battery on the charger. Threw it back in and it started up. So im guessing its probably just getting a bit old. ill try to get it load tested tonight or tomorrow. More than likely it'll just need a new battery.
Reply #7December 10, 2012, 05:39:51 pm
  • 2932
« Reply #7 on: December 10, 2012, 05:39:51 pm »
 Crank it for awhile.
 Even if you have to unplug the pump so it doesn't start.
 Any bad connections will get hot/warm.
