Author Topic: CE1 W terminal tach $60 shipped lower 48  (Read 4807 times)
December 10, 2012, 02:56:50 pm
92EcoDiesel Jetta
« on: December 10, 2012, 02:56:50 pm »
This is a modified CE1 gasser tach and will work from the alternator's w terminal.
CLICK TO PLAY VIDEO!
Reply #1December 10, 2012, 03:32:34 pm
vegged-out
  • 40
Re: CE1 W terminal tach $60 shipped lower 48
« Reply #1 on: December 10, 2012, 03:32:34 pm »
Black = + -  red = +  yellow= W ????
Would it be the same pin out on ce1 deisel tach??
Michiel
Reply #2December 11, 2012, 08:34:52 am
92EcoDiesel Jetta
« Reply #2 on: December 11, 2012, 08:34:52 am »
This W terminal diesel tach can be fitted into a CE1 cluster or work as standalone tach. Just supply power to it and connect it to the W terminal. I modified it to trouble shoot a problem I had while modifying a Westmoreland tack for my Caddy. I got the Westmoreland tach sorted and working and have no need for the CE1 tach. Surely some of you can use a diesel W terminal tach! Make me an offer!
Michiel
Black = + -  red = +  yellow= W ?    ans = yes
Would it be the same pin out on ce1 deisel tach??   ans = I am not sure but I think so.
Reply #3December 11, 2012, 08:43:41 am
« Reply #3 on: December 11, 2012, 08:43:41 am »
50.00 shipped and I will take it...you'll have to tell me how to wire it for sure though.
Reply #4December 11, 2012, 09:12:27 am
92EcoDiesel Jetta
« Reply #4 on: December 11, 2012, 09:12:27 am »
OK, it's a deal! I'll pm you.
Reply #5December 11, 2012, 01:52:46 pm
vegged-out
  • 40
« Reply #5 on: December 11, 2012, 01:52:46 pm »
My reply on the wiring was a question.  I am pretty sure the diesel tach has the same pin outs and I just want to be sure before I wire it in. I have the gasser tach foil but the tach conection was cut off. Is the first (black wire) pin neg (ground), third pin (red wire) pos, and the fourth (yellow) the W connection?
thanks,
Michiel
Reply #6December 11, 2012, 01:59:47 pm
vegged-out
  • 40
« Reply #6 on: December 11, 2012, 01:59:47 pm »
Duhh,
Just re-read your reply and saw your answer at the bottom, guess my mind skipped ahead thinking it was my question re-printed.
Michiel
Reply #7December 11, 2012, 08:53:43 pm
92EcoDiesel Jetta
« Reply #7 on: December 11, 2012, 08:53:43 pm »
Duhh,
Michiel
Sold!
Michiel,
you wrote " Black = + -  "  but you meant " Black = -  "  ? If so yes.
