Author Topic: Factory Diesel Heater?  (Read 3422 times)
December 02, 2012, 07:28:28 pm
« on: December 02, 2012, 07:28:28 pm »
What the heck is this?  Is it actually factory or a modification of a standard flange with an electric fuel heater in the side.   Anyone seen this before.  Guy is advertising it as a WVO heater.  But maybe it could meet others needs for preheating diesel in them butt biting cold areas above the 48th.
Reply #1December 02, 2012, 07:49:51 pm
Re: Factory Diesel Heater?
« Reply #1 on: December 02, 2012, 07:49:51 pm »
I rekon it's a modded MK1 filter flange & banjo bolt. Not sure why there isn't also a bolt-heater on the outlet.
I never thought much of glowplugs in direct contact with un-atomized fuel (even 24V GPs).
Reply #2December 02, 2012, 08:53:04 pm
« Reply #2 on: December 02, 2012, 08:53:04 pm »
Maybe the idea is to heat the WVO so it filters better as a thinner fuel and then actually heat it up to temp for the IP using a proper, ehm nonmodded part, like a FPHE.
Just thought it was over-rated but then maybe not.
Reply #3December 02, 2012, 10:01:51 pm
« Reply #3 on: December 02, 2012, 10:01:51 pm »
I know a guy who did that, but instead of a GP, hw wired a brake light bulb inside the filter.
Funny thing is it never failed.
all the factory ones I've seen are a bigger coil with a lower surface temp.
Reply #4December 04, 2012, 12:33:46 pm
mtrans
  • 308
« Reply #4 on: December 04, 2012, 12:33:46 pm »
I did that meny yr ago,DONT do that.
To mach heat on to small area - carbon in 3 mm hole.
I`ll improve my English
