Author Topic: How much boost pressure should my 1.6 TD have?  (Read 20748 times)
Reply #45December 13, 2012, 03:01:21 pm
Re: How much boost pressure should my 1.6 TD have?
« Reply #45 on: December 13, 2012, 03:01:21 pm »
Hi again
 I seldom ever play the radio so I thought that mounting it lower was not going to affect much. I wanted my gauges somewhere near the line of sight. Obviously the dash cover in my car is bad and something should be done with it.
My marble dash insert is subject to paint but I kind of like it.
I made some tabs on the ends to hold it in place and  I want to make it easily removable as it is still in development. In order to minimize parallax, I glue gunned in the gauge along with a piece of two inch diameter plastic water pipe to angle it.  I didn't have a light for it so I took a white LED out of a small flashlight and soldered a 2k resistor in series with it.
Instead of fishing for a wire controlled by the lighting system I just tinned the leads and stuck them through the dashboard switch of the rear window defogger.  The light should turn on and off with the ignition It only draws about 7 milliamps.
« Last Edit: December 13, 2012, 03:04:47 pm by scrounger »
Reply #46December 13, 2012, 04:14:50 pm
« Reply #46 on: December 13, 2012, 04:14:50 pm »
There is a light stuck in the back of the climate control that is dash light switch controlled. Just for future reference. lol. I'm sure the defrost circuit won't mind 7 milliamps considering the defroster is on its own 20a fuse. haha
« Last Edit: December 13, 2012, 04:16:32 pm by 8v-of-fury »
Reply #47December 13, 2012, 06:04:21 pm
« Reply #47 on: December 13, 2012, 06:04:21 pm »
That would be a good location to hook it up. Once it got dark I realized that 7 ma was not going to make it bright enough. I started reducing the ballast resistance and got acceptable brightness once I got to 60 ma. My LED is quite generic so it might not hold up to long. Should probably science it out with a better LED.
I would like to get a set of VDO gauges so this might be temporary.
Reply #48December 14, 2012, 01:59:51 pm
« Reply #48 on: December 14, 2012, 01:59:51 pm »
Here is another photo showing a closeup of the wedge I put in it.
Also bought a set of VDO gauges on Ebay. Will be mounting them similarly.
