Author Topic: headbolts and headgaskets  (Read 4399 times)
November 26, 2012, 06:52:59 pm
T-ruck
  • 5
« on: November 26, 2012, 06:52:59 pm »
Well!  I've been looking and reading AND searching a very long time, and have enjoyed many hours of info gathering. But the time has come to ask questions.
 SOOO! Here goes
 A friend has bought a 82 Rabbit pickup and it is a 1.6 d [by the block]
IT'S a CR-891-652 block, It has 12mm head bolts BUT these 12's wable in the hole, UNTIL hitting bottom???? using a OLD BOLT.
But when using a 12x1.75 tap and it is snug NO WABLE. Has someone re-taped to 12 OR WHAT?????????. Is this maybe normal/ OR is it time for Studs OR WHAT???????
The other thing is piston height above the deck, I'M getting 34/35 thou or the top end of a 3 notch for a 1.6 OR use a 1.5 4 notch. [If that can be done.]
 There is more to this story but I'm trying to not complicate  it even more
Reply #1November 26, 2012, 07:12:36 pm
bbob203
  • 1789
Re: headbolts and headgaskets
« Reply #1 on: November 26, 2012, 07:12:36 pm »
Stretch bolts.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2November 26, 2012, 07:43:45 pm
« Reply #2 on: November 26, 2012, 07:43:45 pm »
3-notch is good to .0402", hydro or mech.
Reply #3November 26, 2012, 08:33:54 pm
Dakotakid
  • 1240
« Reply #3 on: November 26, 2012, 08:33:54 pm »
What else?
Reply #4November 28, 2012, 03:27:08 pm
shorttimer
  • 121
« Reply #4 on: November 28, 2012, 03:27:08 pm »
Just ordered the ARP head bolts for my AAZ project in a 81Caddy. $178 @ Summit + free shipping. Well I can't say cheap insurance, but I know they can be reused. Got the part #s on this forum. Lots of good info on here, but it takes a lot of looking, sometimes.
Reply #5November 30, 2012, 09:58:33 am
« Reply #5 on: November 30, 2012, 09:58:33 am »
BOLTS?
wasnt aware ARP made head bolts for our engines...
Reply #6November 30, 2012, 11:11:35 am
« Reply #6 on: November 30, 2012, 11:11:35 am »
More food for thought:
I purchased new 12mm bolts to install in a 1.6.
I threaded one new 12mm bolt into all the locations on a 1V block - it was as loose as the old bolts. However, there was less than +.875mm stretch on the old bolts (not even a valley to peak increase on the threads).
New bolt length = 110.4mm (Tip to washer)
Block-Hole depth = 43.5mm
Head-hole depth = 78.8
Gasket = 1mm
Combined hole depth = 123.3mm
Remaining threads in block after threading head and bolts = 13mm 11mm
Bolt threads below head/gasket = 32mm
Head Block recess before threads begin = 13mm
Thread engaged during fastening = 19mm
Edits: see strikethroughs
« Last Edit: December 26, 2015, 03:49:20 am by TylerDurden »
Reply #7November 30, 2012, 11:17:32 am
« Reply #7 on: November 30, 2012, 11:17:32 am »
ive re-used head bolts more than once..
its been stated that its basically safe to re-use the bolts once, provided you know they are OEM, or you know when they were put in..
its still one of those "run at your own risk" kinds of things tho..
my Jetta TD still has a re-used head gasket, and re-used head bolts..
Reply #8November 30, 2012, 11:43:56 am
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
« Reply #8 on: November 30, 2012, 11:43:56 am »
If I can remember it correctly ARP makes a set for a Ford 4 cyl gas engine that has the same bolt dimensions as we do.
I reuse my bolts atleast one time, the same with headgaskets. If no damage ofcourse. I spraypaint them on both sides to fill small scratches etc before mounting them back and tightening the bolts a tad more then the previous time.
<-- My M-tdi Mazda B-1800 and my other cars
Reply #9November 30, 2012, 12:14:28 pm
92EcoDiesel Jetta
« Reply #9 on: November 30, 2012, 12:14:28 pm »
Interesting about the spray paint. What kind do you use and did it always work as far as re-using a head gasket? Not that I will do it unless I have no choice.
Reply #10November 30, 2012, 12:20:29 pm
« Reply #10 on: November 30, 2012, 12:20:29 pm »
ive always used silver floral paint...
the gasket i have now, is treated with nothing..
hell, it was never used on this head/block before, but still had no issues sealing..
Reply #11November 30, 2012, 12:29:46 pm
92EcoDiesel Jetta
« Reply #11 on: November 30, 2012, 12:29:46 pm »
Can I ask what the reason was for reusing an old head gasket?
« Last Edit: November 30, 2012, 04:35:16 pm by 92EcoDiesel Jetta »
Reply #12November 30, 2012, 01:15:04 pm
Sierra94
  • 123
« Reply #12 on: November 30, 2012, 01:15:04 pm »
I use whatever spraypaint I have around. It seems like brand/type doesnt't matter much. One time I was helping a friend with his car and we took the head of 3 times the same night reusing both bolts and gasket. Sprayed the gasket every time and tightened the bolts a little more each time we tourqed them down.
The engine still runs perfect after 10000 km of driving. The problem  was a bent valvestem. The intake valve on cyl #3 was slighly bent causing a popping sound in the intake, but only occasionally. So we had a hard time figuring out what the problem was. But after changing the valve the problem dissapeared.
Reply #13November 30, 2012, 01:16:05 pm
« Reply #13 on: November 30, 2012, 01:16:05 pm »
bent valve coupled with worn guides, and BAM popping out the intake occasionally..
Reply #14November 30, 2012, 01:23:41 pm
Sierra94
  • 123
« Reply #14 on: November 30, 2012, 01:23:41 pm »
I only wish someone stepped in and told us that late that night  ;D but we did the removal/assembly pretty fast the last time including timing the ip.
