Author Topic: First TD winter, running cool  (Read 6256 times)
November 19, 2012, 08:38:53 pm
MusicMech
  • 4
« on: November 19, 2012, 08:38:53 pm »
Hey, so this is the first winter I'll have encountered with my 1994 Golf 1.9TD.  Engine starts and runs great in the cold, and the heater starts cranking out some heat fairly quickly.  However, it never makes it up to what I assume is a normal operating temperature.  The dash gauge used to make it to between 80C and 90C when warmer weather was happening.  Now, even after long periods on the highway or in town, I can't get it to warm up past about 75C.  Is this a sign that the thermostat needs to be replaced, or should I do something for the winter to reduce the efficiency of the radiator?
1994 Golf GL 1.9TD w/intercooler
1978 Super Beetle Convertible - 1776cc fuel injected
Reply #1November 19, 2012, 09:10:51 pm
Re: First TD winter, running cool
« Reply #1 on: November 19, 2012, 09:10:51 pm »
It has nothing to do with the radiator unless the thermostat is not working correctly.  Any time the thermostat is less than fully open, the coolant temperature in the radiator is completely irrelevant to the temperature of the coolant in the engine.  You engine may be running colder due to more cold air rushing over it tho.
Reply #2November 19, 2012, 10:00:00 pm
« Reply #2 on: November 19, 2012, 10:00:00 pm »
My 89 Jetta has the condenser removed and warm-up takes forever; so I block the grille, which allows the fan to still pull air through the radiator if it gets that warm.
Reply #3November 20, 2012, 06:37:32 am
« Reply #3 on: November 20, 2012, 06:37:32 am »
You would be better off blanketing the engine instead of the radiator.  Not only will it have a greater effect (unless the issue is a dysfunctional thermostat) without creating the potential for overheating.
Reply #4November 20, 2012, 07:14:35 am
Hoble
  • 76
« Reply #4 on: November 20, 2012, 07:14:35 am »
Diesels are way more effecient compared to a gas motor meaning that less heat is made during the combustion process. Where I live we often see -10 C and sometimes -25. Tdi's can't even make it to full temp down the highways. You often have to block off a good chunk of the radiator with cardboard or what ever. My mk4 daily idleing for a while in 3*c won't stay at full temp, drops from half way to about a third.
So your problem depends on the temps you are in.
Reply #5November 20, 2012, 07:36:49 am
« Reply #5 on: November 20, 2012, 07:36:49 am »
Yes. The coolant does not flow through the radiator unless the thermostat has opened. When the thermostat opens you should notice a susbllbstantial decrease in temperature as all that cold coolant enters the engine, but it will come back up to and hover around the thermostats temperature rating assuming the engine makes enough waste heat to keep that coolant hot.
You will probably notice that in the winter the engine will run a ton colder, this is not because of the rad. It is because of the engine block and aluminum head acting as a very large surface area heat sink. The coolant is not flowing through the rad but is not being heated enough to maintain a hott enough coola t temps with cold air directly blowing on the engine itself.
I found last winter with my 1.6NA and .71 5th gear cruising at 2300rpm was making no heat and i had trpuble keeping ice off my windshiled.
Reply #6November 20, 2012, 07:41:28 am
« Reply #6 on: November 20, 2012, 07:41:28 am »
Not that they make less heat.. Its that they waste less heat.
Reply #7November 20, 2012, 08:09:48 am
rodpaslow
  • 670
« Reply #7 on: November 20, 2012, 08:09:48 am »
Unless you're really cruising on the highway, using a lot of fuel & boost, you will not have it reach full temperature.  I live in a bit cooler climate than you do in Toronto, with the grill closed off and just putting around Saskatoon, the engine will take forever to heat up.  I can idle it and it and it will actually cool off to about 160° until I start driving it again.  With these IDI's i've found with a good heater core, I have no problems with heat.  I have friends with TDI's that complain about not having enough.
Reply #8November 20, 2012, 02:49:08 pm
Hoble
  • 76
« Reply #8 on: November 20, 2012, 02:49:08 pm »
That's what I was trying say, but couldn't find the correct words. That's what came out haha
Reply #9November 20, 2012, 03:33:04 pm
« Reply #9 on: November 20, 2012, 03:33:04 pm »
they are ~15% more efficient..
so, 15% less heat from the heater.. lol.
Reply #10November 20, 2012, 05:12:53 pm
JamesT
  • 151
« Reply #10 on: November 20, 2012, 05:12:53 pm »
75°C is probably the point your thermostat opens, and it's nearly hot enough for normal engine operation. If it runs at that temperature for too long, my worry would be moisture accumulation in the oil, but that would be pretty minimal at air temps much bellow zero.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #11November 23, 2012, 04:58:56 pm
lloydbiker
  • 37
« Reply #11 on: November 23, 2012, 04:58:56 pm »
Well well, welcome to the club!  I am currently running a 2004 24V 5.9 Cummins, and a '97 AAZ Jetta (380Kkm)(also in past owned a 12v Cummins (600Kkm), an '87 1.6 TD Jetta, and an '83 Merc 220D). All are/were difficult to keep warmed up in winter, unless 'working', with the Cummins 24V being the most stable. I would love to be able to get a 'Radiator Blind' setup, similar to that provided on 50s/early 60s Volvo (like a roll-up window blind without the ratchet, manually operated via a pullchain under the dash), to fit the AAZ, but most just look at me like I'm talking a different language. My solution, in the meantime, is to cut a panel of corrugated cardboard to fit over the top of the engine bay, for the winter. Nothing under there gets hot enough to start a fire, and the panel helps to slow heat loss.
With the old Merc (in Prince George BC at -35c) I would hit the top of 'Airport Hill' at full 'Operating Temp' and coast downhill (about 1 mile), only to see my temp drop to 'Cold'.
« Last Edit: November 23, 2012, 06:45:19 pm by lloydbiker »
Reply #12November 24, 2012, 02:56:31 am
homerj1
  • 433
« Reply #12 on: November 24, 2012, 02:56:31 am »
Last winter on the way back to PEI from Montreal I got stuck in a "traffic jam" for 1/2 hr (due to an accident) and watched the engine temp slowly go from hot to cold.
Really demonstrated the thermal efficiency aspect of my AHU TDI.
