Author Topic: WTB: Vanagon 1.6TD JX engine Injector Lines  (Read 3543 times)
November 16, 2012, 08:32:19 am
ejb
  • 1
« on: November 16, 2012, 08:32:19 am »
I'm looking for a set of Vanagon JX-specific injection lines. These lines are different than other TD lines and NA lines due to the curvature to get around the LDA that is on the 1.6TD injection pump. Here's an example photo: newbielink:http://www.thesamba.com/vw/classifieds/detail.php?id=1387858 [nonactive]
Thanks
Reply #1November 16, 2012, 09:10:05 am
Re: WTB: Vanagon 1.6TD JX engine Injector Lines
« Reply #1 on: November 16, 2012, 09:10:05 am »
Due to your taller AAZ block and taller AAZ injectors (if you use them), the JX lines will not fit.  You will need to bend them anyway.  I would just get a set of four lines that are readily available and bend them to fit. I have a high performance AAZ Vanagon specific pump I built (JX top, 1.6TD body with AAZ camplate and 10mm plunger/head) and have been planning on making custom lines from a set of mercedes 300 lines I have.  I chose the merz lines because they have the correct flares and length and are relatively straight to begin with.
