how much gasoline to add?
by
wdkingery
on 12 Nov, 2012 09:58
i think it mentions it in the owners manual (so i've heard anyway)
but i'd like to know, by volume or percent, how much gas are you adding?
as you know, i'm running a between 50 and 60% motor oil, with the remainder being diesel.
and i've been adding 1/2 a gallon of 93 octane on the fill up, and it seems to like it. this is roughly 5% of the fill up, maybe a little more.
i'm thinking of upping the percentage to about 10% total, or 20% of the motor oil i add (so 5 gallons motor oil, 1 gallon gasoline, remainder diesel)
thoughts?
how will i know when i've gone too far?
#1
by
on 12 Nov, 2012 11:32
It's no longer recommended to run ANY gasoline with your diesel. It used to be ok (Up to 10% I think) when the diesel had more lubrication in it. These days everyone should be adding some lube to their fuel.
Since you are running a crazy mixture of fuel, add as much gas as you want. Eventually it will lower the cetane so much that the car will just quit. The other risk is not enough lubrication to the pump and injectors.
#2
by
on 12 Nov, 2012 12:08
I would think that running motor oil as the main fuel, you are probably set on lubrication. It is not recommended at all to add any gasoline to diesel anymore because of the lack of lubrication in ULSD as it is.
How have you found it has been running on the WMO??
#3
by
wdkingery
on 12 Nov, 2012 13:07
I am willing to go on this same assumption, and begin to up the gasoline quantity.. that will drive my cost down even more, as gas in my area is considerably cheaper than diesel right now.
oooh excellent question! the WMO has actually been very good.
I have had one major issue this whole time.. i actually started a thread about it. it seems the water (water is inevitable) mixes with the motor oil.. I always thought it would just sink to the bottomm but it appears it will mix with the WMO and make mud.. some kind of polymerized mud. this clogged my intake screen in tank, and caused it to run like crap. once i threw that screen away, we have been back in business.
I found that my cost per mile is so low, that instead of driving slowly and trying to get the best MPG possible, drive as FAST AS POSSIBLE! i'm only spending 4.3 cents per mile anyway! this lead to a different realization: if you run the car harder (coupled with a 1.41 injector pump timing,) it causes a much more complete burn, and you end up consuming about the same amount of fuel. and you smoke a lot less. i have reasoned this is because the injectors foul from stop and go and slow driving, and you tend to get the smokes..which gets about 40 mpg. well, on the 75+ MPH long stints with the skinny pedal floored, i still get upper 30's to 40 MPG anyway. so you spend less time in the car, and get the same output. and it likes it better.
the car has done really well on WMO.. better than i anticipated. a turbo would help a lot. i can see from the black smoke i pull away with that i could use more oxygen.
also i was unable to get my valves adjusted exactly correct, as i had a very limited amount of shims (basically all i had was the ones i scavenged from the junkyard.. and they are never the right ones.) so this could be limited air intake as well.
i had to pull the tank to get the screen out, and i found some shiny metals in the bottom of the tank. but the tank appeared to have never been down since 1985 so.. i don't know if i'm steadily wiping my IP out or not. we will see with time.
thanks for askin!
#4
by
on 12 Nov, 2012 15:15
Thank you for going in to so much detail! With both my brother and myself being in the mechanical trade we both have thousands of gallons of WMO available to us.. Most of which has sat a good long time. So your polymerized mud experience should be all at the bottom. From my readings however it doesnt seem to be the metal or particles in the engine oil that causes a problem, but the additives in it that were never meant to be burnt. Have you noticed any symptoms of lost compression? Also iirc you have been at this a long time.
#5
by
410
on 12 Nov, 2012 16:28
I would recommend using the lowest octane fuel available instead of the highest octane. Octane is pretty much the exact opposite of cetane so they counteract each other. The best thing to use to thin your fuel in my opinion is heptane, better known as Naptha or coleman fuel. Heptane has a very low octane rating but the problem is finding a cheap source. I have an old Mercedes manual that mentioned using up to 5% gas in diesel for colder climates. It also mentions using up to a liter of engine oil in the fuel to reduce black smoke under load.
#6
by
shorttimer
on 12 Nov, 2012 17:54
Yesterday I viewed a Youtube video about using a centrifuge to clean oil. I was skeptical before watching, however I was amazed at how clean the oil looked after the process. It was mentioned that it cleans down to 1/2 micron, which is pretty damn small, and it saves a bunch of other messy steps to get clean oil. For as much as it's costing me to get this engine in my Caddy, I'll be doing that process for cleaning any of the used oils, if I'm inclined to go that route.
#7
by
on 12 Nov, 2012 18:03
Was it pabiodieselsupply? If not, I suggest checking them out. They supply an extremely affordable full kit that has EVERYTHING.
It is not the "dirtiness" of motor oil that is necessarily the problem with running it.. it is the additives that are in motor oil for motor oil, that weren't meant to be burnt.
#8
by
wdkingery
on 12 Nov, 2012 20:40
The compression.
I had just re-ringed this spring, and quite honestly I don't think the rings finally settled until this high speed driving I've been doing. I have a prothe compression tester, and it ain't worth a damn. But it said I was in the 150's before the ring job, and 300 psi after :-( but I only tested once, and it was shortly after the rebuild. So maybe it went.. Up. It does seem to cold start better; in fact, we got a 29f the other night here in Virginia, and it fired up quickly. The wmo does make a cold start considerably tougher. And if it does fire and you don't rev it, it might cut off on you. During this time injector coking is prevalent. So it's best to get up to rpm straight away. I actually start it and go straight to 3k rpm when it's real cold. I know it seems mean to the motor.
The centrifuge.
I did want to get a centrifuge. I even got a power steering pump from the bone yard, and even got a washing machine motor out of the trailer behind home Depot (where they store all the used appliances.. They rarely lock it.. Just walk up in there and steal a motor!) but, the centrifuge is like $160, and a 1 micron bag filter shipped is $5. And it's like Jeremy said; it doesn't appear to be the ***tle that's in the oil, it's the additives and the water/goat vomit that is the problem. I propose you could probably just pour the oil in straight from the source and let the fuel filter on the car do the work.. Probably would work fine.
#9
by
mtrans
on 13 Nov, 2012 12:06
-I propose you could probably just pour the oil in straight from the source and let the fuel filter on the car do the work.. Probably would work fine.
Never,never do that,centrifuge is must for wmo.
#10
by
on 13 Nov, 2012 13:41
I dont know the clearances of the internals of the pump.. But they seem to go hundreds of thousands of miles with just the 15 micron filter protecting them..
A fuel filter when you change your oil would probably be a good enough change interval.. And arent they like $8 a pop for a filter?? Stupid cheap.
I do like your way of the power steering pump and the washer motor... But that $700 kit includes that the centrifuge and every necessary fitting and hose to make it all ready to go.
#11
by
wdkingery
on 13 Nov, 2012 13:45
Yeah but the whole point of me driving this car, and further the whole point of the wmo is to save money. Then I need a $700 filter? So I am cutting every corner possible lol. The power steering pump and washer motor were free, and the centrifuge would have been $160 at pabiodiesel. So that's a large cut. I chose to cut it a whole lot more and just get a $5 bag filter (good to a micron!)
But if you youtube the ps pump/washer motor/centrifuge assembly its definitely possible.
#12
by
on 13 Nov, 2012 19:58
Oh yeah, its possible. but with all the screwing around the full kit seems tantalizing.
It is not a $700 filter, it is a $700 centrifuge kit. Put 55g of old oil in, walk away for 6 hours and when you come back you have oil that has been filtered to less than half a micron.
Now the filter bags work as well, how well? I have no idea. Do you have to clean them out?
#13
by
wdkingery
on 13 Nov, 2012 20:04
No when they start getting slow I throw them away considering they are five bucks a pop.
#14
by
on 13 Nov, 2012 20:06
I was starting a several (55 gal) drum stock pile when I came across evidence leading to the extreme loss of compression due to running on WMO. It seems the additives in motor oil will in fact coke the rings and piston tops making for hot spots and loss of compression.
I have since reconsidered running WMO.. and it sucks because I have huge supply
