Author Topic: cold start question  (Read 6400 times)
November 10, 2012, 05:32:57 am
vwroadkill
  • 137
cold start question
« on: November 10, 2012, 05:32:57 am »
here we go.. again I am new to diesels. I recently set my timing. ambient temps those days was in the mid 90's, now as the weather has the temp dropping in my area to the low 30's at night, I am having a difficult time starting and stay running . unless I pull cold start out wait for glow plug light to go out, attempt to start. it catches and dies. do this two or three time and then maybe. at the fifth attempt it will catch and run. but I cant figure why.. do I need to reset timing. plug in engine warmer.. is there some vodoo I am missing.. chicken bones .. maybe slaughter the neighbors cat to pay homage{ will do that anyways} lol.. thoughts ideas..
Dan
new owner of an 81 caddy diesel yipeeeee..vw gti vr6 and well most of gm's trucks
Reply #1November 10, 2012, 05:49:13 am
Re: cold start question
« Reply #1 on: November 10, 2012, 05:49:13 am »
Cover the basics:
    Clean fuel filter
    No air bubbles in the lines (use clear line in/out)
    Fast cranking (good starter & bushing, battery, heavy cables)
    ~48A draw on glowplugs (indicates all good)
    >300psi on all cylinders
Reply #2November 10, 2012, 05:52:37 am
vwroadkill
  • 137
« Reply #2 on: November 10, 2012, 05:52:37 am »
thanks the basics are covered.. Iam just skeptical that I timed the engine for one temperature. and will have to time it for another.. cause it wont  start like it did before..
Dan
Reply #3November 10, 2012, 06:22:52 am
« Reply #3 on: November 10, 2012, 06:22:52 am »
Any white/grey smoke?
Colder ambient temps can exacerbate tuning issues; an engine tuned for easy starting in the cold should not need re-tuning for warmer seasons.
There are folks who assert that older (non-rebuilt) engines can benefit from additional advance.
I time "by ear", turning the IP to the cusp of increased clatter (@idle, engine warm), then back-off a hair.
Reply #4November 10, 2012, 06:46:15 am
vwroadkill
  • 137
« Reply #4 on: November 10, 2012, 06:46:15 am »
white smoke.yes..it does this ALOT. Does this mean I have it to fat.. heavy fuel.. should I lean it out... most of my experience is on aircraft engines, jets mostly.. so I am getting it just not like I want ..
I hear the clatter as it starts and then is smoothes out..
would I benefit from getting my injectors replaced... think vw installed these.. only 137k on the clock but the car was sitting before I bought it and I have driven it maybe one tankful at best.
pump is new
Reply #5November 10, 2012, 08:27:41 am
« Reply #5 on: November 10, 2012, 08:27:41 am »
White smoke usually indicates retarded timing. Dark smoke usually means overfueling.
I distinctly hear clatter until the engine is up to temperature.
Injectors have to be pretty bad to significantly effect starting.
Reply #6November 10, 2012, 11:12:08 am
CarlosA
  • 139
« Reply #6 on: November 10, 2012, 11:12:08 am »
Part of the cold start process when very cold is to have the pedal floored. I use this, get it started, pull the cold start, and still feather the throttle for a while as it warms up. Same on both my cars.
Reply #7November 10, 2012, 02:24:25 pm
bbob203
  • 1789
« Reply #7 on: November 10, 2012, 02:24:25 pm »
Do you happen to work for us airways? I notice you live near charlotte.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #8November 10, 2012, 02:25:51 pm
bbob203
  • 1789
« Reply #8 on: November 10, 2012, 02:25:51 pm »
THIS is a great tip. But i only find it neccesary down below 15 f. Sounds like you could advance your timing a hair and it would be good.
03 Jetta wagon TDi
Reply #9November 10, 2012, 09:47:36 pm
JamesT
  • 151
« Reply #9 on: November 10, 2012, 09:47:36 pm »
I don't understand this phrase:
It's not an unless. That is the procedure for starting in cold weather. If you do not pull the cold start and wait for the glow plug light to go out, it will be difficult to start.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #10November 11, 2012, 03:36:14 am
« Reply #10 on: November 11, 2012, 03:36:14 am »
On my mom's 84 Jetta I advance the timing for the winter. I like the quietness of the retarded timing but it just doesn't cut it in the winter.
Reply #11November 11, 2012, 04:40:43 am
vwroadkill
  • 137
« Reply #11 on: November 11, 2012, 04:40:43 am »
ok.. lot of questions and input, I will answer.
the normal range of temps here in the southeast US get down to a bismal 20f at worst... so I didnt think I would have to worry about cold weather procedures. noted.. I will use the plug that is hanging off the back of the engine to warm it up. lol.
I do not work for USAIRWAY's. would like to. but I work for the AirForce and have for the last 28 years. Im a C-130 mech.
I will try the pedal floored method to start and use the cold start knob to keep it running method,
as well as add some advance to the IP.
thanks for the info..
I will post some pictures of the upgrades to my truck. new front sheetmetal. floor pans , wheels tires , interior coil overs.
Dan
Reply #12November 11, 2012, 05:59:17 am
« Reply #12 on: November 11, 2012, 05:59:17 am »
I used the same method on my 86 TD with shot rings... Heater, floored, glow, crank and pull CS when the engine catches. The cranking would bog-down if the CS were pulled beforehand.
All my other 1.6 require the CS pulled to light-off quickly. I'm pretty sure they all have good compression.
Reply #13November 11, 2012, 10:46:56 pm
mystery3
  • 774
« Reply #13 on: November 11, 2012, 10:46:56 pm »
I could be wrong about many things this included but I thought to start a cold engine regardless of ambient temps you first want to pull the cold start handle, burn the glow plugs until the indicator light goes out then start the engine. Drive normally for a few minutes and push the cold start lever back in as soon as the temps gauge begins to move off the resting position. I'm fortunate never to have to start in temps below the high 20's F so don't have any experience starting in truly cold weather.
Reply #14November 11, 2012, 11:35:30 pm
CarlosA
  • 139
« Reply #14 on: November 11, 2012, 11:35:30 pm »
Yeah you can pull it ahead of time but like Tyler said, if its very cold it will bog down. To be honest I didnt even run a cold start cable last winter and just spent a few more seconds feathering the throttle before running back in the house for 5 minutes...
