Author Topic: 1.9d dies when running.  (Read 3182 times)
October 29, 2012, 06:43:38 am
Farlos
  • 17
« on: October 29, 2012, 06:43:38 am »
1.9d 1y motor code,it has a really bad start, but when it starts and get running, it will die at any moment, when it gets to 3000rpm for example, and i want to let it coast for a second the engine will drop the rpm and die, then again bad start and the same, at the moment is un-runnable because of this problem.
Any ideas?
Reply #1October 29, 2012, 07:24:49 am
Re: 1.9d dies when running.
« Reply #1 on: October 29, 2012, 07:24:49 am »
Air in the fuel.
Reply #2October 29, 2012, 09:31:12 am
Farlos
  • 17
« Reply #2 on: October 29, 2012, 09:31:12 am »
and how do i check this? i think i need some clear fuel lines to see it as i have them on my TDi, also, how can i adress this issue?
Thanks for the fast reply libbydiesel
Reply #3October 29, 2012, 11:37:13 am
« Reply #3 on: October 29, 2012, 11:37:13 am »
What vehicle is this installed in?
Reply #4October 29, 2012, 12:31:00 pm
Farlos
  • 17
« Reply #4 on: October 29, 2012, 12:31:00 pm »
1997 seat ibiza
Reply #5October 30, 2012, 07:17:15 am
CrazyAndy
  • 739
« Reply #5 on: October 30, 2012, 07:17:15 am »
Yup, clear fuel supply lines will aid in diagnosis.  Don't forget to get a clear return line, as that will help you know if your injector return lines might be leaking.
Got any noticeably damp spots on your injection pump?
Reply #6October 30, 2012, 07:45:36 am
« Reply #6 on: October 30, 2012, 07:45:36 am »
Go along the fuel lines under the vehicle all the way to the tank and make sure that none of the hose clamps have rotted off.
How old is your fuel filter? Have you checked the one in the tank (assuming there is one)?
Reply #7November 14, 2012, 08:28:51 am
Farlos
  • 17
« Reply #7 on: November 14, 2012, 08:28:51 am »
already olved it, the return line was broken and it sucked air at higher than 2500 rpm, it also made starting really difficult, now i want to delete the non working Air conditioner , what size belt do i need to get?
Reply #8November 14, 2012, 08:58:18 am
« Reply #8 on: November 14, 2012, 08:58:18 am »
Pretty sure the last page of this link will tall you
http://www.vwdiesel.net/forum/index.php?topic=9599.0
That is assuming this thing is set up like a VW
Reply #9November 14, 2012, 11:33:24 pm
Farlos
  • 17
« Reply #9 on: November 14, 2012, 11:33:24 pm »
it is a VW engine, code 1Y, also used in some mk3 VW golf, it has only one v belt and one serp belt and the timing belt, i assume is the same as a AAZ engine, hope it helps a bit.
Reply #10November 15, 2012, 04:56:58 am
« Reply #10 on: November 15, 2012, 04:56:58 am »
That sounds the same as VWs setup.
Reply #11November 15, 2012, 09:03:52 am
Farlos
  • 17
« Reply #11 on: November 15, 2012, 09:03:52 am »
is the v belt running the water pump or if it breaks only the power steering pump will stop working?
Reply #12November 15, 2012, 12:18:25 pm
« Reply #12 on: November 15, 2012, 12:18:25 pm »
V belt likely runs the power steering and water pump. Where the serp has the alt and ac if so equipped.
