Author Topic: 1.6 non AC setup  (Read 3692 times)
October 23, 2012, 02:09:16 pm
1.6 non AC setup
« on: October 23, 2012, 02:09:16 pm »
Pulled from a mk2, I'm fairly certain it will fit a Mk1 no problem. Alternator is tested and works, no bearing noises. I have the PS pump and can include that if needed. I have the belts as well and will include them. They are used. The harmonic balancer is showing signs of aging (rubber cracking). The tensioner is the toothed style to make adjusting the belt a lot easier. Note that the pulley bolts are included and in good shape. $75+ shipping for everything pictured (plus the belts).
http://smg.photobucket.com/albums/v603/burnyourmoney/?action=view&current=IMG_0013.jpg
Reply #1October 24, 2012, 07:41:17 pm
Dakotakid
  • 1240
Re: 1.6 non AC setup
« Reply #1 on: October 24, 2012, 07:41:17 pm »
Pm'ing you with some questions.
Reply #2October 25, 2012, 06:46:32 pm
« Reply #2 on: October 25, 2012, 06:46:32 pm »
Pulleys are sold. I only have the alternator. I swapped on a different pulley that is the correct offset (+/- 3mm) $40 +shipping.
