Author Topic: b3 passat wagon 16v to MTDI swap *Glow plug wiring time*  (Read 70038 times)
Reply #60November 08, 2012, 01:01:07 pm
bbob203
  • 1789
Re: b3 passat wagon 16v to MTDI swap.
« Reply #60 on: November 08, 2012, 01:01:07 pm »
How can I clean out the intake ports on the head? I pulled my manifolds and there is some serious crud caked on the intake ports.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #61November 08, 2012, 03:52:50 pm
Reply #62November 08, 2012, 06:50:13 pm
bbob203
  • 1789
« Reply #62 on: November 08, 2012, 06:50:13 pm »
This stuff is caked on so thick like <1/4" is it the egr that causes it to cake up like this?
03 Jetta wagon TDi
Reply #63November 08, 2012, 07:20:13 pm
« Reply #63 on: November 08, 2012, 07:20:13 pm »
It is EGR soot mixed with oil mist from the crank vent.  Eliminate either one and it won't build up.
Reply #64November 09, 2012, 05:15:27 am
« Reply #64 on: November 09, 2012, 05:15:27 am »
Either pull the cam or rotate it so the valve is closed on the port you are working on. Then vacuum or blow it out.
Reply #65November 13, 2012, 07:11:18 am
bbob203
  • 1789
« Reply #65 on: November 13, 2012, 07:11:18 am »
Would using a 96 passat vr6 for my project be a giant pain in the ars sinve its obd2?
03 Jetta wagon TDi
Reply #66November 14, 2012, 12:20:31 pm
« Reply #66 on: November 14, 2012, 12:20:31 pm »
Since you are going mechnical i dont see why it should matter ?? Lol.
Reply #67November 14, 2012, 12:44:46 pm
bbob203
  • 1789
« Reply #67 on: November 14, 2012, 12:44:46 pm »
From a removal of wiring standpoint. O2 sensors yada yada. I hate abs. I'm lookin to maybe do it with a 96 vr6 auto that's in bass shape with a bum trans for less than 2 grand only 60k on the body. I guess what I'm asking is will my brakes work by just disconnecting the abs control from the ecu when I take it out? The seller suggests I just get a b3 aaz harness.
03 Jetta wagon TDi
Reply #68November 16, 2012, 05:48:15 am
bbob203
  • 1789
« Reply #68 on: November 16, 2012, 05:48:15 am »
New receiver of my mtdi if all goes as planned.
http://denver.craigslist.org/cto/3321303085.html
« Last Edit: November 16, 2012, 08:49:56 am by bbob203 »
03 Jetta wagon TDi
Reply #69November 16, 2012, 10:13:25 am
jboogie13
  • 175
« Reply #69 on: November 16, 2012, 10:13:25 am »
just to put my 0.02$ in, i would say that glowplugs are essential, not optional. Yes the care will start but i feel like it is very unhealthy for the engine especially on cold starts. The coolant glowplugs help get the engine up to operating temp faster as the tdis take longer to heat up than our IDI's. Im also going to vote for the hydro clutch, theyre really just as reliable as a cable if you use parts in good condition (maybe out of a b4 or ahu jetta? seeing as they're still available new)
Reply #70November 16, 2012, 10:16:03 am
bbob203
  • 1789
« Reply #70 on: November 16, 2012, 10:16:03 am »
I have decided on going hydro clutch.
03 Jetta wagon TDi
Reply #71November 18, 2012, 12:40:24 pm
bbob203
  • 1789
« Reply #71 on: November 18, 2012, 12:40:24 pm »
looks like the g60 flywheel by sachs and the vr6 clutch kit is the way to go.
03 Jetta wagon TDi
Reply #72November 18, 2012, 01:36:14 pm
« Reply #72 on: November 18, 2012, 01:36:14 pm »
yep.... to clutch...
b4 = junk... b3 better quality...
abs sux... not easy to remove...
by the way.. the 97 passat tdi got hit when i was on my road trip... still working on the totaled or not aspect.. but complete tdi-e swap... all maintence done even..
Reply #73November 25, 2012, 05:53:12 am
CdnVWJunkie
  • 309
« Reply #73 on: November 25, 2012, 05:53:12 am »
How so?  Their window reg's suck, sure but essentially the same cars.  I've a bunch of them over the years.  Looks-wise, the facelifted B4 wins  hands down.
Reply #74November 25, 2012, 06:02:54 am
bbob203
  • 1789
« Reply #74 on: November 25, 2012, 06:02:54 am »
I kinda like the space shuttle look of a white b3.
03 Jetta wagon TDi
