Author Topic: So I lost 5th gear tonight,  (Read 2451 times)
October 18, 2012, 08:28:55 pm
Turbofan
  • 70
« on: October 18, 2012, 08:28:55 pm »
On the way down to brew night at a friends house. There I was, cruising down 95, then nothing. I knocked it back into 4th and finished my ride. Sounds like a common enough problem, and that the gear just came loose. My question is, should I need to replace 5th, is there something taller that will fit?
I drive an '86 Golf, with a turned up IP and a non stock vnt, so I'm not afraid of gear height . Thanks all, hope your motoring adventures aren't including the unfortunate sound of whirring unconnected gears.
Reply #1October 18, 2012, 08:43:19 pm
DanV990
  • 20
Re: So I lost 5th gear tonight,
« Reply #1 on: October 18, 2012, 08:43:19 pm »
A .71 gear is the tallest offered.
Reply #2October 18, 2012, 08:49:29 pm
DanV990
  • 20
« Reply #2 on: October 18, 2012, 08:49:29 pm »
The bottom of your bell housing has a code on it. Match it up the the list linked below to know what you already have in your transmission. If you already have a .71 you can't go any taller for fifth gear.
http://www.scirocco.org/gears/
Reply #3October 19, 2012, 05:06:54 am
Turbofan
  • 70
« Reply #3 on: October 19, 2012, 05:06:54 am »
Looks like I have an .75, though I took a peak at my junk collection and it looks like I have an old 4sp that has a .71 4th gear. What are the chances it'll fit?
Reply #4October 19, 2012, 05:33:13 am
bbob203
  • 1789
« Reply #4 on: October 19, 2012, 05:33:13 am »
www.brokevw.com email him he will answer all your questions.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #5October 19, 2012, 02:21:17 pm
« Reply #5 on: October 19, 2012, 02:21:17 pm »
it wont fit..
4th gear doesnt work as a 5th..
the difference between a .75 and .71 is about 25 rpms, so not really enough to justify the change..
