Author Topic: FS: used working t3 turbo  (Read 3391 times)
October 18, 2012, 02:21:36 pm
damac
  • 531
« on: October 18, 2012, 02:21:36 pm »
I yanked this off the car I have been driving a while.  Seems to do the job just like the others I have had with stock fueling/blowoff valve settings.  Just bare turbo, no drain line like pictures below.  This sucker was leaking like crazy with that drain line.  Also I think the fitting on the bottom of the turbo needs attention because of leaks.  When I put it back in service I just used what was there, a little piece of rubber jammed into metal pipe through the turbo hole with a dab of rtv and it didn't hold up.  I have seen some people tap that hole with a fitting which makes sense.  The turbo I have on my latest engine has done the same.
When looking at the turbo inlet I can't tell if somebody painted the fins?  Looks like some black is flaking off and there is buildup that should be cleaned up.
$150 shipped to us good?
http://smg.photobucket.com/albums/v44/kellyass/?action=view&current=PA171547PA171547PA171547.jpg
http://smg.photobucket.com/albums/v44/kellyass/?action=view&current=PA171548PA171548PA171548.jpg
http://smg.photobucket.com/albums/v44/kellyass/?action=view&current=PA171549PA171549PA171549.jpg
« Last Edit: October 18, 2012, 09:38:41 pm by damac »
1985 turbo diesel jetta
