Author Topic: F.S. ACN 020 transaxle  (Read 5944 times)
September 30, 2012, 10:53:50 am
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
« on: September 30, 2012, 10:53:50 am »
As stated ACN 020 transaxle from an 8V gasser, works great coupled to a 1.6TD, ask ROR2.0.....
133,000 miles $250 picked up
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #1October 01, 2012, 12:21:41 pm
Re: F.S. ACN 020 transaxle
« Reply #1 on: October 01, 2012, 12:21:41 pm »
its the trans that SHOULD HAVE cone behind a TD..
i LOVE mine..
2400revs @ 60mph..
cruising 80 on the freeway doesnt make me cringe anymore...
thats LOW MILES too..
Reply #2October 25, 2012, 04:54:07 pm
GTiTDi
  • 153
« Reply #2 on: October 25, 2012, 04:54:07 pm »
Sold
Reply #3October 26, 2012, 05:19:27 am
bbob203
  • 1789
« Reply #3 on: October 26, 2012, 05:19:27 am »
To whoever bought it there is. .71 fifths for sale on vortex def worth it. I love mine.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4October 27, 2012, 12:26:20 pm
« Reply #4 on: October 27, 2012, 12:26:20 pm »
for 25 rpms?
not worth it....
Reply #5October 27, 2012, 03:30:38 pm
bbob203
  • 1789
« Reply #5 on: October 27, 2012, 03:30:38 pm »
for 25 rpms?
not worth it....
More like 150 @70mph w/  185/65r14
03 Jetta wagon TDi
Reply #6October 28, 2012, 09:41:24 am
« Reply #6 on: October 28, 2012, 09:41:24 am »
for 25 rpms?
not worth it....
ok, 130 rpm..
i still dont think 130rpm is worth spending money on, and then splitting the case..
if you had a .91 5th gear or something like that, then this would be great..
its really not necessary to upgrade, bing that .75 is the second tallest 5th gear..
if you are dropping 5-600 revs, like you would be going from a .91 to a .71, then its way worth it..
ive never felt like it was worth it to upgrade for barely a change in engine tone tho...
Reply #7October 28, 2012, 10:13:24 am
bbob203
  • 1789
« Reply #7 on: October 28, 2012, 10:13:24 am »
for 25 rpms?
not worth it....
ok, 130 rpm..
I get what you are saying I guess I just wanted to do it to have the experience of changing a fifth gear and still getting a negligible benefit is a plus...
03 Jetta wagon TDi
Reply #8October 28, 2012, 12:42:00 pm
« Reply #8 on: October 28, 2012, 12:42:00 pm »
for 25 rpms?
not worth it....
ok, 130 rpm..
find a junk 020 (not hard, they always blow up) and split the case and perform all different kinds of surgery!
then you dont have to worry about messing up the trans in your daily driver.. doesnt really matter if you mess up your "learning" trans..
thats what i did atleast.. ive always taken apart the junk trans first, when i do something trans related that ive never done before..
Reply #9October 29, 2012, 06:26:16 pm
GTiTDi
  • 153
« Reply #9 on: October 29, 2012, 06:26:16 pm »
split the case? ::) I have changed 5th gears numerous times with the transaxle in the car....pretty easy as a matter of fact. Same deal with 02A for the most part.
Reply #10October 29, 2012, 06:53:59 pm
bbob203
  • 1789
« Reply #10 on: October 29, 2012, 06:53:59 pm »
:thumbsup: you just gotta remove the six 5th gear housing bolts to get to it. Remove the 27mm selector plug detent bolt shift it into 2 gears a brake loose the 12mm xzn triple square bolt on big gear remove circle clip on the other pop off the adjuster tab loosen the barrel nut adjuster deal and use a puller on the gear took me 30 minutes round trip on the bench trans out of car already while i was doing a swap.
03 Jetta wagon TDi
Reply #11October 29, 2012, 07:37:57 pm
« Reply #11 on: October 29, 2012, 07:37:57 pm »
well, i meant that figuratively speaking..
5th gear doesnt need a case split..
just the end case split from the main case..
