For Sale/Looking For
Parts for Sale/Wanted
FS: unknown injection pump?
Topic: FS: unknown injection pump? (Read 3789 times)
September 11, 2012, 10:24:05 pm
damac
September 11, 2012, 10:24:05 pm »
Long story short I'm hoping somebody can use this stuff for parts because its of no use to me so best offer. Pump came off a rabbit im bringing back to life that had a turbo diesel motor. Supposedly running fine one day, then nothing and I can tell they didn't know what they were doing. I tried to soak in atf a couple days, used my electric pump and ran lines from a jug. I did not get to check timing but he said it was never touched. The reason why is it wasn't worth effort and you should have seen the whacked way it was setup so you had to take alt bracket off to get to bolt underneath pump!
http://smg.photobucket.com/albums/v44/kellyass/injectionpumpsale/
Last Edit: October 18, 2012, 01:00:04 pm by damac
1985 turbo diesel jetta
November 11, 2012, 06:56:34 pm
Re: FS: unknown injection pump?
November 11, 2012, 06:56:34 pm »
Still got this?
November 11, 2012, 09:37:33 pm
damac
November 11, 2012, 09:37:33 pm »
yeah, what the hell is it?
November 12, 2012, 08:37:26 am
November 12, 2012, 08:37:26 am »
I'm not sure what it is. The number looks like it has an 8mm plunger like the 1.6ECOdiesel pumps. It also has the long delivery valves which came on the ECO pumps. It does not have any timing advance on the back of the pump, tho. It also doesn't have the port in the case for the line from the solenoid on the dynamic piston. Looks like a mix 'n' match...
Last Edit: November 12, 2012, 08:39:46 am by libbydiesel
November 12, 2012, 10:37:59 am
November 12, 2012, 10:37:59 am »
Could it be an industrial pump? It says "IND. BRASIL" on it which I think means "industry of Brazil" not necessarily an industrial pump.
