Author Topic: self adjusting to manual clutch cable.  (Read 4605 times)
September 06, 2012, 05:35:53 am
bbob203
  • 1789
« on: September 06, 2012, 05:35:53 am »
can I reuse the bushings and release arm anchor plate?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1September 06, 2012, 05:55:08 am
Re: self adjusting to manual clutch cable.
« Reply #1 on: September 06, 2012, 05:55:08 am »
No they are torque to yeild pieces of sheet metal and rubber, one time use only...
Did you really just ask this question?
Reply #2September 06, 2012, 06:58:12 am
« Reply #2 on: September 06, 2012, 06:58:12 am »
rubber piece in tranny different for the 2 sstyles... the rubber piece on arm where cable hold down goes can also be different... one is thicker/longer then the other..
Reply #3September 06, 2012, 08:29:55 am
bbob203
  • 1789
« Reply #3 on: September 06, 2012, 08:29:55 am »
ok thanks. that's what I was looking for.
03 Jetta wagon TDi
Reply #4September 06, 2012, 09:22:56 am
« Reply #4 on: September 06, 2012, 09:22:56 am »
ive always re-used both pieces with no ill side effects..
Reply #5September 06, 2012, 09:40:42 am
bbob203
  • 1789
« Reply #5 on: September 06, 2012, 09:40:42 am »
I got down to the garage and messed with a bit looks like it should work with the self adjusting bushings and anchor plate.
03 Jetta wagon TDi
Reply #6September 06, 2012, 09:42:36 am
« Reply #6 on: September 06, 2012, 09:42:36 am »
IT DOES!!
trust me, ive done it.. took auto cable out, threw it away, and used manual..
