Author Topic: *SOLD* 1.6 TD / 1.9 TD / TDI turbo manifold + twin plenum intake  (Read 7663 times)
August 17, 2012, 12:31:31 pm
TurboJ
  • 661
***ALL OF THE BELOW HAVE BEEN SOLD***
Unused turbo manifold for VAG 8V engines
Fits all VAG 8V engines with counter-flow heads. Yep, fits both gas and diesel engines.
For example Golf II 1.6 and 1.8, Golf III 1.8 ja 2.0, all 1.6 D / TD ja 1.9 TD and also 1.9 TDI.
(click for a bigger pic)
Specs:
* T25 flange
* Proven to at least +300 hv on VAG diesel engines
* Proven to provide great spool-up
* Thoroughly cleaned, sand blasted and ceramic coated with proper oven treatment
* Made by a respected professional (Aki76) modifying a OE exhaust manifold
* Fits great with the intake below
Slight work needed to use: grind the flange flat (we didn't complete this because of a switch to another type manifold)
and tap two of the bolt holes. After that it's bolt on and enjoy!
The "crack" in the picture is not a crack but a cast mark from the VW factory :)
Price 135 USD + shipping
Aki design twin plenum -intake manifold for all 1.9 D / TD / TDI -engines.
(klikkaa suuremmaksi)
* Extremely good flow. Easily surpasses all ready-to-fit alternatives.
* IMSA-style design, perfected by Aki76 :)
* Twin plenum design allows for even flow to all cylinders -> big power with safety.
* 50 mm pipe connector with grooves to keep a hose in place
* Ideal manifold to boost mid range power and torque ( 2500 to 5000 rpm )
* Thoroughly cleaned, sand blasted and painted, clear coated with many layers. Is pretty.
* Fits all 1.9 heads with the "horse shoe" inlet port.
* Fits great with the exhaust manifold above
Price 200 USD + shipping
T25 -exhaust flange and both gaskets. New.
* Only the exhaust manifold flange is missing (is welded on the turbo manifold above)
* Ideal combination for the aforementioned turbo manifold
* Fits T2 and T25 -series Garretts, Schwitzer S1- series, etc.
Price 20 USD + shipping
Parts' location is in Finland, but I will ship worldwide.
Good price for a package deal (and the shipping could be cheaper than you think)
PM me for more info!
« Last Edit: August 21, 2012, 11:48:56 am by TurboJ »
Jetta II 1.6 TD 'Project 200'
Reply #1August 19, 2012, 09:36:57 pm
Powered by Spearco
  • 1203
Re: FS: 1.6 TD / 1.9 TD / TDI turbo manifold + twin plenum intake
« Reply #1 on: August 19, 2012, 09:36:57 pm »
PM sent.  ;)
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #2August 19, 2012, 09:57:52 pm
Alcaid
  • 549
« Reply #2 on: August 19, 2012, 09:57:52 pm »
PM sent.  ;)
Too late, because I'm buying the manifolds ;)
'10 VW Passat 1.6TDI Highline
Reply #3August 21, 2012, 11:49:37 am
TurboJ
  • 661
Re: *SOLD* 1.6 TD / 1.9 TD / TDI turbo manifold + twin plenum intake
« Reply #3 on: August 21, 2012, 11:49:37 am »
Yep, sold they are.
Reply #4August 21, 2012, 01:47:47 pm
Powered by Spearco
  • 1203
« Reply #4 on: August 21, 2012, 01:47:47 pm »
Yeah, good for you. Hope they will complete your build.
 :D
'13 Golf R:. Tuned
'98 Puch G320
