Author Topic: WTB - Audi 40004/Quantum diesel Alternator Brackets  (Read 5716 times)
August 05, 2012, 12:46:55 pm
Toby
  • 728
« on: August 05, 2012, 12:46:55 pm »
I am looking for the alternator/ power steering pump brackets for a 4000 or Quantum diesel. Right now the alternator sits where the IP will go.
« Last Edit: August 05, 2012, 08:42:20 pm by Toby »
Reply #1August 05, 2012, 01:03:04 pm
Re: WTB - Audi 4000 diesel Alternator Brackets
« Reply #1 on: August 05, 2012, 01:03:04 pm »
quantum should have the same setup.. and may be easier to find as well.
Reply #2August 05, 2012, 10:35:34 pm
Re: WTB - Audi 40004/Quantum diesel Alternator Brackets
« Reply #2 on: August 05, 2012, 10:35:34 pm »
dasher too... more diesel dashers then td quantiums.. same for 4k audi..
im thinking it same as a vanagon/mk1 no ac bracket...
Reply #3August 06, 2012, 12:22:20 am
  • 2932
« Reply #3 on: August 06, 2012, 12:22:20 am »
Yep. same as A1 non-AC alt bracket.
Reply #4August 06, 2012, 08:19:52 am
« Reply #4 on: August 06, 2012, 08:19:52 am »
I've seen a few n/a Audi 4ks in the junkyard here. I haven't seen a Dasher in decades. Is this part desirable to a lot of people? I'll pull next time I see one if it is.
Reply #5August 06, 2012, 10:07:10 am
lovinthedeez
  • 489
« Reply #5 on: August 06, 2012, 10:07:10 am »
I have the vanagon/mk1 non a/c bracket.   ;D
Reply #6August 06, 2012, 10:25:32 am
« Reply #6 on: August 06, 2012, 10:25:32 am »
The Vanagon and mk1/mk2 Rabbit/Golf/Jetta do not share ANY brackets or pulleys (actually PS pulley might be the same...) with the Quantum/Audi 1.6TD belt drive system.  IIRC, the Quantum TD mounts the A/C pump and alternator on the manifold side of the engine.  Injection pump, water pump and power steering go on the injector side of the engine.  I have all the parts for at least one complete 1.6TD Quantum belt drive system with accessories minus the split water pump pulley.
« Last Edit: August 06, 2012, 10:27:22 am by libbydiesel »
Reply #7August 06, 2012, 11:35:34 am
Toby
  • 728
« Reply #7 on: August 06, 2012, 11:35:34 am »
The A/C pump is on the manifold side, so it looks like there would not be enough room for the alternator there. What I probably need id a photo of one to compare it with.
Reply #8August 06, 2012, 11:37:53 am
Toby
  • 728
« Reply #8 on: August 06, 2012, 11:37:53 am »
Would you be willing to sell the alternator/AC brackets?
Reply #9August 06, 2012, 07:02:51 pm
« Reply #9 on: August 06, 2012, 07:02:51 pm »
Yes, I'd be willing to sell the parts.  Here's a picture of a friend's car:
By the manifold, in front of the air inlet tube you can see the alternator poking out.  If you need more pics of the mounting, I can get them, but it might take a couple days.
Reply #10August 06, 2012, 08:38:54 pm
Toby
  • 728
« Reply #10 on: August 06, 2012, 08:38:54 pm »
Thanks. That is where the A/C pump is on mine (IIRC). Does yours have A/C? If so, a pic of that bracket would be most helpful.
J
Reply #11August 06, 2012, 10:08:56 pm
« Reply #11 on: August 06, 2012, 10:08:56 pm »
A/C is mounted right below the alt.  IIRC they share the same bracketry.  I don't have a picture off hand (friend's car).  I can get more pics but it might take a couple days.
Reply #12August 07, 2012, 09:56:57 am
Toby
  • 728
« Reply #12 on: August 07, 2012, 09:56:57 am »
That would be wonderful! Thanx.
Reply #13August 11, 2012, 03:58:24 pm
« Reply #13 on: August 11, 2012, 03:58:24 pm »
It's really hard to get decent pictures due to the radiator fans and intercooler pipes being in the way.  Here's the best I could do:
The A/C crank pulley is a split design with adjustment shims.  The alt has a slot adjustment under it.
Reply #14August 12, 2012, 10:49:09 pm
Toby
  • 728
« Reply #14 on: August 12, 2012, 10:49:09 pm »
Thanks. That is exactly what I need. The A/C compressor is now where the alternator needs to go. What would you take for your extra set?
J
