Author Topic: Turbo ---Oil supply issue  (Read 4972 times)
August 03, 2012, 04:14:18 pm
mtnbob
  • 738
« on: August 03, 2012, 04:14:18 pm »
I have my turbo all hooked up, but there seems to be no place for the oil feed. Bentley shows it coming from the oil filter mount, but mine is from an N/A and that fitting is missing. Do I need a turbo specific oil filter mount that includes a fitting for the oil feed, or can I drill out mine and put threads in it?
Thanks
96 Subaru Outback Wagon
Reply #1August 03, 2012, 05:32:19 pm
bbob203
  • 1789
Re: Turbo ---Oil supply issue
« Reply #1 on: August 03, 2012, 05:32:19 pm »
if your adding a turbo to naturally aspirated motor you need a new oil filter housing and/with an oil cooler. and 2 different/extra coolant lines and a different coolant pipe the hard one running from thermostat housing and terminating right before the heater core.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2August 03, 2012, 06:22:46 pm
mtnbob
  • 738
« Reply #2 on: August 03, 2012, 06:22:46 pm »
I'm putting a turbo on a turbo block, but I'm trying to use the oil filter bracket from my N/A. It is all I have to work with. I had already put a fitting on where the sensor attached, and used that to hook up my oil pressure gauge and the sensor.
Reply #3August 03, 2012, 10:03:08 pm
« Reply #3 on: August 03, 2012, 10:03:08 pm »
I tapped mine to NPT and used an NPT to 5/16" flare.
Reply #4August 04, 2012, 09:29:07 am
bbob203
  • 1789
« Reply #4 on: August 04, 2012, 09:29:07 am »
What lib said(though ive never tried it). You may also be able to run it it off the sensor if you remove it and run an oil press. gauge @ the head which i would recommend anyway.
03 Jetta wagon TDi
