Author Topic: Quick ac bracket question  (Read 2349 times)
July 28, 2012, 11:19:43 am
camboscams
  • 324
« on: July 28, 2012, 11:19:43 am »
Can the ac bracket that bolts to the engine be removed without removing the injection pump and bracket? Its a mk1 1.6l btw
« Last Edit: July 28, 2012, 11:24:26 am by camboscams »
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #1July 28, 2012, 11:24:49 am
justiz00
  • 54
Re: Quick ac bracket question
« Reply #1 on: July 28, 2012, 11:24:49 am »
I just went thru this on my 1.6na. and sadly I could not do it. If you have the motor out of the car then you should be able to get upper left one but the upper right is hidden behind the pump.
Reply #2July 28, 2012, 01:39:39 pm
bbob203
  • 1789
« Reply #2 on: July 28, 2012, 01:39:39 pm »
You might be able to do it with 1/4 extensions and a uni joint socket. but what he said. :-\
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #3July 30, 2012, 08:30:06 am
« Reply #3 on: July 30, 2012, 08:30:06 am »
Can sometimes be done with an "S" wrench. Not easy if the bracket has been on for a decade.
Reply #4July 30, 2012, 12:34:45 pm
camboscams
  • 324
« Reply #4 on: July 30, 2012, 12:34:45 pm »
Gotcha hopefully i will be that lucky. time will tell
Reply #5July 31, 2012, 06:10:25 pm
CarlosA
  • 139
« Reply #5 on: July 31, 2012, 06:10:25 pm »
I actually *had* to do that on an engine I was working on last week. The lower bolt for the IP had broken loose of its bracket and was just spinning - couldnt get in there to hold it without removing that bracket, was a nightmare for sure, but this wrench helped:
I usually use it for adjusting the IP.
Reply #6July 31, 2012, 07:03:18 pm
« Reply #6 on: July 31, 2012, 07:03:18 pm »
I cannot remember which bolt, but I have a set of flex head gearwrench and it will almost go anywhere. The only hang ups are if the head of the bolt or nut is recessed or blocked in that way. IIRC I can get all the hard to get IP bolts with it...and it is the handiest 13mm wrench I own for other things.
