Author Topic: wtb td injector lines  (Read 4317 times)
July 24, 2012, 01:50:44 pm
bbob203
  • 1789
« on: July 24, 2012, 01:50:44 pm »
I'm looking for a quality set of turbo diesdl injector lines didn't realize I need to swap out the injector lines to when converting to a true td pump.   ::)
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1July 25, 2012, 05:58:45 am
Re: wtb td injector lines
« Reply #1 on: July 25, 2012, 05:58:45 am »
You don't "need" new lines. You can time the pump 1 tooth off (I forget what way) and that will allow the LDA to clear the line.
That said I'm 90% sure I have a set. They could be AAZ, I'll have to double check. PM me with your postal/zip code if you are interested
Reply #2July 25, 2012, 10:05:55 am
bbob203
  • 1789
« Reply #2 on: July 25, 2012, 10:05:55 am »
So thats the only difference is the line clearing the lad? i thought the the length of delivery valves had something to do with it? That being said i have an ada pump that would have lines that clear the lda but maybe delivery valves on that are the same long ones as on an eco pump?
03 Jetta wagon TDi
Reply #3July 25, 2012, 03:06:50 pm
bbob203
  • 1789
« Reply #3 on: July 25, 2012, 03:06:50 pm »
2 lines work 2 don't its a matter of length of delivery valves. 8mm and ada pump long delivery valves. lda td pump has shorter delivery valves. I don't see how pushing pump forward would help. if you push pump away from engine the gear would go ccw one tooth. I have all 3 types of pump right here within arms length. how about those lines?
03 Jetta wagon TDi
Reply #4July 25, 2012, 03:14:56 pm
« Reply #4 on: July 25, 2012, 03:14:56 pm »
Sorry, I thought you had just replaced a NA pump with a TD pump. I forgot you Americans got those silly eco diesels with the different length delivery valves. I didn't look today, but I will do my best to remember to tomorrow.
Reply #5July 25, 2012, 05:43:28 pm
« Reply #5 on: July 25, 2012, 05:43:28 pm »
Just swap the delivery valves with the lines.
Reply #6July 25, 2012, 06:06:30 pm
bbob203
  • 1789
« Reply #6 on: July 25, 2012, 06:06:30 pm »
hmmm ok if libby is telling me this i feel a little safer. Ive read though that the delivery valves are shimmed according to the pump or something ???. why the shorter on the td vs the longer on the eco/ada pumps? whats the difference in valve?
03 Jetta wagon TDi
Reply #7July 25, 2012, 09:15:03 pm
« Reply #7 on: July 25, 2012, 09:15:03 pm »
As long as you don't mix and match the pieces you should be fine swapping the delivery valves. Keep everything in order in case you have to swap back though.
I found the set I was thinking of and it is definitely not AAZ. I want to check it on my car first because I did have a set of eco lines just for fun but I don't know where they got off to.
Reply #8July 26, 2012, 01:24:35 pm
« Reply #8 on: July 26, 2012, 01:24:35 pm »
You may need to adjust the max fuel after swapping delivery valves.  Other than that I have not been able to detect any operational difference with different delivery valves even the TDI ones which are a markedly different design.
