Author Topic: 1.9TD low power and leaking oil  (Read 3863 times)
July 20, 2012, 01:27:32 pm
strawhouse
  • 7
« on: July 20, 2012, 01:27:32 pm »
Heres one I need to figure out, I've got a 1988 Doka with a 1.9TD in it.  Originally the truck had a 1.6TD in it but it ran into some problems and I pulled it out and installed the 1.9 which had around 80,000 km's.  What has happened is the 1.9TD was running great after the switch, then about 3 months in the injector pump started to leak.  I took the injection pump off of the 1.6TD engine ( which was rebuilt 500km's prior ) and installed it.  The power was OK but it never seemed quite right.... never the less I played around with the timing and I found the best spot and left it. (cant remember the setting on the dial indicator ).
What then started to happen was the engine started to loose oil, oil at high speeds only, It was a fine mist that would soak the back of the Doka.  We pressure washed the engine and we could never find the culprit.  When I removed the oil cap on the valve cover when it was running we never felt any large amount of air or any oil being forced out, as well with the dipstick.  I have never seen oil come out of the exhaust nor oil in the coolant.
At this point now the 1.9TD is really lacking power, low end power but it drives at highway speeds.  Big hills really slow the doka down.  I know that they are bad for power but this is really bad.  At this point I am thinking of pulling the engine and putting a new one in.... but before I do that I just want to hear any thoughts or suggestions, maybe there is something I am missing I should try before pulling it out, ..... let me know!
