Author Topic: Help sourcing turbo Renault J8S for Leharo, similar to D24T Volvo  (Read 6911 times)
July 13, 2012, 08:09:58 am
houseofdiesel
  • 210
Need help finding a couple of turbos for my 1984 Winnebago Lesharo motorhomes, the wastegates have rusted out on both, one is still working ok up to 15psi, the other howls above 8psi. I have a spare core turbo that is dead and needs a cartidge for comparison, it is physically very similar to the D24T 6 cyl VW engine as found in the Volvo 740, a T3 exhaust flange, similar housing, one line fitment is different and it is clocked differently also. It is a Garrett turbo, but no id tags left...
I am just looking to keep these units running, old cores are fine if they are not rusty...or NOS stock etc. I don't want to lay out $1000 on rebuilt turbos right now unless all else fails in my search.
Greg
Reply #1July 13, 2012, 08:52:18 am
Re: Help sourcing turbo Renault J8S for Leharo, similar to D24T Volvo
« Reply #1 on: July 13, 2012, 08:52:18 am »
you need new turbos it sounds like, not wastegates..
maybe check for boost leaks, if one howls above 8psi.
Reply #2August 12, 2012, 10:51:54 pm
Toby
  • 728
« Reply #2 on: August 12, 2012, 10:51:54 pm »
What rusted out on the waste gates? The actuator or the exhaust housing?
Reply #3August 13, 2012, 06:32:58 am
« Reply #3 on: August 13, 2012, 06:32:58 am »
Can you post detailed pictures?  They may not be proprietary
Reply #4August 13, 2012, 08:36:53 am
houseofdiesel
  • 210
« Reply #4 on: August 13, 2012, 08:36:53 am »
So far I have found out they are Garrett TAO305 turbos, only fitted to that model of engine (Renault J8S XXX), the Volvo is a TAO307 and the same 0.36 A/R. Mercedes is also similar but bigger .42 A/R TAO304/314. All these turbos are obsolete, yes rebuildable but expensive ($1000-1600 quotes). Working on pics.
Reply #5August 13, 2012, 08:45:23 am
« Reply #5 on: August 13, 2012, 08:45:23 am »
http://www.vwdiesel.net/forum/index.php?topic=31392.0
bet it won't be close to that with them
Reply #6August 13, 2012, 09:25:25 am
« Reply #6 on: August 13, 2012, 09:25:25 am »
G-Pop Shop FTW!!!
Reply #7August 13, 2012, 01:37:20 pm
houseofdiesel
  • 210
« Reply #7 on: August 13, 2012, 01:37:20 pm »
Vw TAO304 based t3 is also similar (1.6 td turbo)...might have to go with it. My problem with rebuilds is the parts I have are rusted badly, I won't get many years of service or they will call and say it was a no go with the core, the waste gates are missing, meaning not there rusted away years ago and the exhaust housing doesn't look much better. I will contact xsboost and see though...
