Author Topic: FS: Standard 76.50mm bore 1.6 TD OEM pistons  (Read 3850 times)
June 27, 2012, 08:05:35 am
« on: June 27, 2012, 08:05:35 am »
I have 8 good pistons that are I believe Klobenschmidt, but are the OEM out of the 2 MF code TD engines I had. I was going to reuse, but the block needs bored. I need to buy new pistons, so help me out.
Add 4 of these Goetze standard rings 1 set per piston   068198151C   *part # for http://www.autohausaz.com*   to your cart for approx. 100.00 and buy these pistons for 100.00 per set and you have the best rings and pistons you could come up with for the cost of Prothe pistons.
These are not oversized, these are standard 76.50mm
Reply #1June 28, 2012, 07:31:10 am
Re: FS: Standard 76.50mm bore 1.6 TD OEM pistons
« Reply #1 on: June 28, 2012, 07:31:10 am »
This would be perfect for someone that has an N/A and wants to go turbo.
Reply #2July 02, 2012, 06:31:05 am
« Reply #2 on: July 02, 2012, 06:31:05 am »
Anyone? Make some offers if you are interested. I have 4 ready to ship.
Reply #3July 05, 2012, 06:03:56 am
« Reply #3 on: July 05, 2012, 06:03:56 am »
x2
