General Information
Troubleshooting
Leaking dip stick hole
Topic: Leaking dip stick hole (Read 4674 times)
June 25, 2012, 10:20:31 pm
June 25, 2012, 10:20:31 pm »
I figured this might be a common but quiet topic. My dip stick tube weeps oil where it meets the block. I know that the tube gets pressed into it so i hammered it some more but it still leaks quite a bit. Enough for me to smell in the car, drop off the pan and make a mess!
Does anyone have a source for new tubes and the tappered piece it fits into or any other suggestions? I figured that silicone sealer would not work but is it worth a try?
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
June 25, 2012, 10:47:14 pm
Re: Leaking dip stick hole
June 25, 2012, 10:47:14 pm »
not all are... the dipsticks that bolt to the ip bracket have o-rings... and yes silicone helps too... only if you piull it.. and add it to the o-ring..
Last Edit: June 25, 2012, 10:48:50 pm by CRSMP5
June 25, 2012, 11:00:48 pm
June 25, 2012, 11:00:48 pm »
Mine bolts to the IP! Ill pull it out and see if there is even a ring in there.
THROWN ROD
June 26, 2012, 06:27:39 am
June 26, 2012, 06:27:39 am »
I put a SAE washer or a metric washer on mine that bolts to the IP. I put the washer on, then the O ring, to help smash it down and in 40,000 miles I didn't have one drop come up from there.
Round 2
July 03, 2012, 11:00:53 am
July 03, 2012, 11:00:53 am »
Thanks for the tip!
THROWN ROD
July 03, 2012, 10:17:13 pm
wolf_walker
July 03, 2012, 10:17:13 pm »
Gray "high-torque" silicone fixed mine. JB Weld did not, just FYI. Mine was the o-ring type, with a new one, go figure.
Mentat Text Two
General Information
Troubleshooting
