TDI Engine -General Info
AHU air conditioning in mk1 chassis
Topic: AHU air conditioning in mk1 chassis (Read 18149 times)
June 18, 2012, 07:58:10 pm
1life2live
June 18, 2012, 07:58:10 pm »
Planning on doing a tdi swap into my mk1 and would like to retain the ac. I have read that the compressor will hit the core support with the new motor. Just curious if anyone has made it work and what it took. Also besides making the compressor fit what will i need to hook it into the 84 jetta ac lines?
June 18, 2012, 11:42:17 pm
Re: AHU air conditioning in mk1 chassis
June 18, 2012, 11:42:17 pm »
yep the front panel needs cut.. then box in the cut out... really not that bad.. ive seen a few pics...
lines.. custom... hhave to splice the old lines with new style fittings...
June 19, 2012, 05:48:50 am
1life2live
June 19, 2012, 05:48:50 am »
Great thanks. Notching should not be a problem. You have any links to the pictures you speak of?
June 19, 2012, 07:54:16 am
June 19, 2012, 07:54:16 am »
it was on poortex... mk1 rabbit/jetta discussion area.. good 18mo ago.. thinking one was a caddy build.. the other was rabbit/jetta and that one they used a curved piece to box it in.. but no no links... i saw them way before i put my tdi into the kubvan.. when the plans were my 84 coupe..
the guy i think id talk too is the daily fun tdi mk1 jetta that he bucheed with the wrong offset porsche phone dials... he changed th firewall for the later heaterbox.. kept the ac and such.. but i do not know how he modded the coresupport..
June 28, 2012, 03:19:09 pm
punkvideo81
June 28, 2012, 03:19:09 pm »
Here's the thread with the mk1 Jetta tdi build on vortex, good luck.
http://forums.vwvortex.com/showthread.php?5240680-My-mk1-TDI-daily-funmobile.-Speedy-Build-thread-lol./page2
'81 Caddy 1.6 TD
June 28, 2012, 04:52:29 pm
1life2live
June 28, 2012, 04:52:29 pm »
Yea I actually commented on it and have yet to get a response thanks though
July 08, 2012, 07:07:28 am
G60ING
Corrado TDI
July 08, 2012, 07:07:28 am »
here you go:
http://forums.tdiclub.com/showthread.php?t=281944
July 14, 2012, 04:50:54 pm
1life2live
July 14, 2012, 04:50:54 pm »
That's perfect thanks
July 16, 2012, 08:07:54 pm
erice1984
July 16, 2012, 08:07:54 pm »
How did you solve your lower radiator hose fitment issue?
Did you get a different radiator? Please share the radiator size or vehicle it was made for.
I am in the midst of doing my own AAZ into MK1 rabbit and made the notch in the metal for the AC compressor and then I went to fit the radiator and more issues.
Thanks!
1980 Rabbit 1.9TD
July 27, 2012, 09:42:37 pm
July 27, 2012, 09:42:37 pm »
Is there any space in front of the A/C condenser to mount an air to water intercooler radiator?
July 28, 2012, 06:38:56 am
July 28, 2012, 06:38:56 am »
I don't believe there is. I don't know for sure on the MK1 but I know with a/c and the MK2 there isn't. Here is a whoretex thread that started talking about valves and on page 2 is turning into a really good IC discussion
http://forums.vwvortex.com/showthread.php?5672840-Diesel-valves/page2
There is a link to the MK1 section of the shorty valve cover thread that is pretty good. I think it is based off of the car CRSMP5 has been talking about everytime this comes up called the yellow zonker
Round 2
Reply #11
July 28, 2012, 03:05:07 pm
Reply #11 on:
July 28, 2012, 03:05:07 pm »
I skimmed the link but it look like all the discussion was on air to air intercoolers which are considerably thicker than the radiators available for air to water systems. On my rabbit I will install A/C and air to water charge cooler, one way or another.
Reply #12
July 28, 2012, 04:36:49 pm
Reply #12 on:
July 28, 2012, 04:36:49 pm »
yes, my bad I should have explained better. If you would take this idea you could build an air to water IC under hood in conjunction with the intake.
Round 2
Reply #13
July 28, 2012, 05:45:43 pm
Reply #13 on:
July 28, 2012, 05:45:43 pm »
Yeah, for quite some time I've been planning to build an air water intercooler combined with a n/a intake manifold for a dual plenum air to water intercooler/intake. I was just curious if the intercooler's radiator would fit in front of the A/C compressor. My car doesn't currently have A/C and so I can't readily measure. I was thinking that a complete A/C system from a mk3 might not be too hard to come by for a retrofit.
Reply #14
July 28, 2012, 07:27:28 pm
Reply #14 on:
July 28, 2012, 07:27:28 pm »
no room... less room then a mk2 has...
mk3 box in mk1 = lots of work... pics above/other page that guy did do mk3 into mk1 ac/heat...
