Author Topic: airflow question/picture request idi  (Read 3471 times)
June 18, 2012, 04:46:26 pm
jhax
  • 328
« on: June 18, 2012, 04:46:26 pm »
Hello Everyone,
Picking up my new to me 86 golf westy diesel on saturday and I have a question. I am not looking for uber amounts of power or anything and i am in the process of building an ALH TDI monster for the car over the next couple of years and until then i know airflow is the best thing for the little IDIs. Has anyone just cut (very cruel way of putting it) a hole in the top of the hood right above the airbox and formed a plastic housing that creates a seal around the hole? Is rain water ever a problem with this? Please dont burn me im not new to the car scene nor the VW mk2 scene i am just curious as to if this is a better option than running a pipe or hose from the airbox to the fender.
Here is the little car sitting on a little lot in OKC
And here is n example of the cut (i hate using that word) in question.
Any input or images would be appreciated.
Excited to finally have a MK2 diesel golf.
Justin
Reply #1June 18, 2012, 06:08:15 pm
  • 4553
Re: airflow question/picture request idi
« Reply #1 on: June 18, 2012, 06:08:15 pm »
You sure that hood opening goes to the airbox and not to the interior venting?  The owner deleted all the stock vent grills and did a single wiper install so I am thinking he vented that opening to the existing rain tray and is not incurring water into the engine.  It may work as you say but as i watch the rain crawl up the hood of my car I would question that particular set up.  I might turn it around as the windshield actually creates a heck of a lot of pressure when moving forward.  That is why you get air thru the vents at 60 without the fan on.  Grabbing air out of the raintray might be just as good or better than through a tube up front.
Any takers on that one?
DAS
Reply #2June 18, 2012, 06:43:24 pm
jhax
  • 328
« Reply #2 on: June 18, 2012, 06:43:24 pm »
yeah kind of like an inverse cowl the wind vortecies flow backward under the hood and into the air box. any other input or design pictures would be great!
Reply #3June 18, 2012, 06:45:50 pm
« Reply #3 on: June 18, 2012, 06:45:50 pm »
rain bad... takes very little liquid to bend a rod... yes ive bent one in a small goofy river of water vs the lakes i hit way before that... filter got saturated vis lakes... the small flow 1/4 mile from home killed it..
Reply #4June 18, 2012, 07:10:50 pm
jhax
  • 328
« Reply #4 on: June 18, 2012, 07:10:50 pm »
bummer dude. so stick with the dryer hose. winkie face
Reply #5June 18, 2012, 07:16:40 pm
« Reply #5 on: June 18, 2012, 07:16:40 pm »
You'd probably be deaf within a week or two
Reply #6June 18, 2012, 09:06:23 pm
  • 4553
« Reply #6 on: June 18, 2012, 09:06:23 pm »
I'm deaf now, just ask the wife.  I drive a diesel what more do I need to say.
Is he calling you winkie face?  or adding that to his post like this?   ;)
Reply #7June 18, 2012, 09:16:53 pm
jhax
  • 328
« Reply #7 on: June 18, 2012, 09:16:53 pm »
the ladder, i choose the break away from the norm of the stupid emoticon bull and write out the emoticons i seem fit. i.e. smiley face, one eyebrow raised face, angry face
Reply #8June 18, 2012, 09:38:10 pm
  • 4553
« Reply #8 on: June 18, 2012, 09:38:10 pm »
Interesting bit of nuance,  got a location?
Reply #9June 22, 2012, 09:15:00 pm
JamesT
  • 151
« Reply #9 on: June 22, 2012, 09:15:00 pm »
The idi intake has some small drain holes in the bottom, the actual intake runners are only open in the top quarter of the housing.
If you opened up the drains a bit (and filtered them) the rain water may not be a problem. Are you hoping for a ram effect, or just for a clean, simple source of cool air? If the former, you may be doing more harm than good: just cutting a vent in a hood may not create a high pressure space and may actually create a low-pressure zone. If the latter, what's wrong with a bit of hose running to the stock hole in the passenger fender? If it's a clean engine bay issue, just make it a solid pipe and shiny.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
