Author Topic: broke main bearing cap #3.... need advise to find replacement.  (Read 3774 times)
June 10, 2012, 06:24:16 pm
redscare
  • 15
So, I did not double check the lower thrust washers on both sides and installed main bearing caps.  breaking #3 as it was pressing into the improperly installed lower thrust washer.
So now the question.... What cars use a non-integrated thrust washer?  Will any non diesel cap work?
From reading, I assume any water-cooled from 1980 and on has reliefs cut into the main cap?
I have a 1.6 L gas block with integrated bearings and no reliefs cut into the cap.  pick-n-pull might be my answer, but do not want to open up half a dozen oil pans till I find the right one.
Also, I damaged the lower thrust washer, so I need a replacement as well.  Any place that sells them for less that $30?  Found them at parts place inc, reliable source, but they could be less expensive.
Thanks in advance. This site has been a tremendous help over the years with my little rabbit.
Reply #1June 10, 2012, 06:45:37 pm
81 vw pu
Re: broke main bearing cap #3.... need advise to find replacement.
« Reply #1 on: June 10, 2012, 06:45:37 pm »
Not sure on what year main caps will interchange, but when you find the correct one the block needs to align bored.
