Author Topic: for sale k24/k26  (Read 10625 times)
June 10, 2012, 10:35:56 am
andy2
for sale k24/k26
« on: June 10, 2012, 10:35:56 am »
I have a k24/k26 that I wouldn't mind parting with.I built it about 4 yrs ago and intended to use it but never did.There is a couple pics of it in the links below.
http://andy2turbo.multiply.com/photos/album/12#photo=1
http://andy2turbo.multiply.com/photos/album/12#photo=2
http://andy2turbo.multiply.com/photos/album/12#photo=3
It isn't rebuilt just reconditioned.It has ceramic coated turbine housing that was bored out to accept the k26 turbine wheel.The k26 compressor section is mounted to the k24 center housing.The wastegate is stock and in good working order.I made a spacer out of an old exh manifold to clearance the k26 compressor housing from the intake manifold.The turbine outlet flange holes were drilled and tapped for 10mm as we were planing on hanging another turbo form it.The 8 capscrews and spacer are included with this as well.
This turbo is obviously not a bolt on and would require a modified oil drain pipe hose due to the exh spacer.The compressor inlet and outlet are also different sizes that the k24.
looking $200 + shipping
« Last Edit: June 10, 2012, 10:39:08 am by andy2 »
Reply #1June 10, 2012, 11:27:19 am
Re: for sale k24/k26
« Reply #1 on: June 10, 2012, 11:27:19 am »
is this a K26 center section inside K24 housings?
or is it a K26 cold side on a K24 turbo?
Reply #2June 10, 2012, 01:22:22 pm
1.9aaz
« Reply #2 on: June 10, 2012, 01:22:22 pm »
cash today for 200 shipped to Pa 18360
Reply #3June 10, 2012, 01:33:04 pm
1.9aaz
« Reply #3 on: June 10, 2012, 01:33:04 pm »
On second thought.... i'll split shipping with you if your willing
Reply #4June 10, 2012, 08:08:41 pm
andy2
« Reply #4 on: June 10, 2012, 08:08:41 pm »
This is k26 wheels with a k24 turbine housing bored out to accept the bigger k26 turbine wheel.It has a k24 center section not the k26 water cooled one.
Reply #5June 11, 2012, 06:23:06 am
1.9aaz
« Reply #5 on: June 11, 2012, 06:23:06 am »
Hi Andy,
Should I take your lack of response as a "not interested"? No hard feelings, just wanting to know if I should bid for one on ebay.
Andrew
Reply #6June 11, 2012, 12:03:58 pm
« Reply #6 on: June 11, 2012, 12:03:58 pm »
ok, so it was built right then..
good deal!!
Reply #7June 11, 2012, 02:55:24 pm
andy2
« Reply #7 on: June 11, 2012, 02:55:24 pm »
Hi Andy,
Andrew
As long as the shipping isn't too much then I'm sure we could work a deal.I can get a shipping quote likely tomarrow.
Reply #8June 11, 2012, 03:23:27 pm
1.9aaz
« Reply #8 on: June 11, 2012, 03:23:27 pm »
Thanks! I look forward to hearing from you.
Reply #9June 13, 2012, 08:36:41 pm
CrazyAndy
  • 739
« Reply #9 on: June 13, 2012, 08:36:41 pm »
did 1.9aaz take it already?
Is the K26 compressor inlet O.D. larger than a K24?
Reply #10June 14, 2012, 04:48:47 am
andy2
« Reply #10 on: June 14, 2012, 04:48:47 am »
Yes,I will hopefully be shipping it out to him today.
I'm pretty sure that the compressor inlet OD is smaller for some reason.
Reply #11June 14, 2012, 03:00:53 pm
andy2
« Reply #11 on: June 14, 2012, 03:00:53 pm »
SOLD
Reply #12June 14, 2012, 03:14:15 pm
« Reply #12 on: June 14, 2012, 03:14:15 pm »
Compressor inlet is SMALLER on the 26. the compressor wheel is MUCH larger, but the inlet is SMALLER for some reason..
Reply #13June 14, 2012, 03:38:18 pm
1.9aaz
« Reply #13 on: June 14, 2012, 03:38:18 pm »
Thanks Andrew!
Cant wait to post pics and and how she performs.
Andrew
Reply #14June 15, 2012, 12:45:31 pm
CrazyAndy
  • 739
« Reply #14 on: June 15, 2012, 12:45:31 pm »
Okay, no prob.  So inlet OD is smaller, wierd.  Have fun w/ that turbo for me!
So 2 other guys her named Andrew too?  Crazy!  8)
