Author Topic: AAZ Cam in a 1.6TD  (Read 5923 times)
May 12, 2012, 04:51:14 pm
kaneb
  • 164
    • www.dasdubbers.org
AAZ Cam in a 1.6TD
« on: May 12, 2012, 04:51:14 pm »
Any info on this? Is it do able and perhaps a power upgrade?
Discuss
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #1May 12, 2012, 04:56:01 pm
Re: AAZ Cam in a 1.6TD
« Reply #1 on: May 12, 2012, 04:56:01 pm »
Discuss
no. the 1.6 cam is hotter..
Reply #2May 14, 2012, 03:51:54 am
Alcaid
  • 549
« Reply #2 on: May 14, 2012, 03:51:54 am »
Do you have more info on that?
'10 VW Passat 1.6TDI Highline
Reply #3May 14, 2012, 04:54:53 am
« Reply #3 on: May 14, 2012, 04:54:53 am »
http://www.vwdiesel.net/forum/index.php?topic=25149.0
Not to mention the base circles are different between the mechanical valve and hydro valve engines, if you were thinking of going that way. It could work, but from what I gather over 50-100k miles the vibration transfered into the valvetrain will wreck it and the cam.
« Last Edit: May 14, 2012, 05:06:10 am by theman53 »
Reply #4May 14, 2012, 05:15:05 am
Alcaid
  • 549
« Reply #4 on: May 14, 2012, 05:15:05 am »
The info in that link is comparing apples and oranges.. There is no info there on the hydro 1.6TD cam which would be the one to compare against an AAZ cam.
Reply #5May 14, 2012, 06:30:40 am
« Reply #5 on: May 14, 2012, 06:30:40 am »
Very good point sir. You should measure the hydro cam and get back to us.
Reply #6May 14, 2012, 07:44:19 am
nathan_b
  • 361
« Reply #6 on: May 14, 2012, 07:44:19 am »
been running 1.6td hydro cam in my aaz head on 1.6 block for 15k miles, cam and lifters looked great when resetting the timing yesterday.
Reply #7May 14, 2012, 11:36:37 am
Alcaid
  • 549
« Reply #7 on: May 14, 2012, 11:36:37 am »
I have a hydro 1.6TD cam lying around, but don't have a Cam Doctor available, sorry  :(
« Last Edit: May 14, 2012, 12:05:56 pm by Alcaid »
Reply #8May 14, 2012, 12:01:09 pm
« Reply #8 on: May 14, 2012, 12:01:09 pm »
no, ive just heard of LOTS of people running hydro 1.6 cams in their AAZ heads..
people say the 1.6 cam is hotter, i dont have any factual evidence...
Reply #9May 15, 2012, 01:48:03 pm
nathan_b
  • 361
« Reply #9 on: May 15, 2012, 01:48:03 pm »
Valve Timing - Up to 1985 - 1.6 L
Inlet valve opens........5 ATDC
inlet valve closes........13 ABDC
Exhaust valve opens....27 BBDC
Exhaust valve closes...5 BTDC
Valve Timing - from 1986 - 1.6l - JK and RA engine
Inlet valve opens........6.5 Atdc
inlet valve closes........13,5 ABDC
Exhaust valve opens....25,5BBDC
Exhaust valve closes...6.5 BTDC
Valve Timing - 1.9l - 1Y and AAZ
Inlet valve opens........6 ATDC
inlet valve closes........20 ABDC
Exhaust valve opens....25.5 BBDC
Valve Timing - 1.9 l - 1Z
Inlet valve opens........16 ATDC
inlet valve closes........25 ABDC
Exhaust valve opens....28 BBDC
Exhaust valve closes...19 BTDC
Reply #10May 16, 2012, 08:48:18 am
kaneb
  • 164
« Reply #10 on: May 16, 2012, 08:48:18 am »
I just read somewhere recently that someone was running a 1.9l cam in a 1.6 and thought if it was a good mod. all of us would have installed one already. :D
www.dasdubbers.org
