Author Topic: WTB, 1.6 alternator bracketry  (Read 3783 times)
May 08, 2012, 10:40:53 pm
masterbeavis
  • 88
« on: May 08, 2012, 10:40:53 pm »
I need the alternator swing arm bracket, the one that's a mile long...  Here is a pic of it before I took the motor apart and apparently threw it away (along with the water pump pulley)
It has to come from a factory AC engine with the alternator on the top of the motor and no power steering.
I am also interested in possibly converting to a non AC style alternator bracket, with related pullies.   My suction hose has some of the material eaten by a rat, unsure if the system will hold a vacuum.
81 Caddy Diesel, 84 Jetta Diesel, 98 Jetta GLS, 99 Jetta GLX,, 95 Golf.
Reply #1May 09, 2012, 06:48:27 pm
Re: WTB, 1.6 alternator bracketry
« Reply #1 on: May 09, 2012, 06:48:27 pm »
hmm, the a/c system has quite high PRESSURE, so idk why it would be important for your hoses to hold vacuum.. the outter layers of the hose do almost nothing.. they are just there for protection. the inner layers are what actually hold the pressure.
BTW, its not a suction hose, its a LOW PRESSURE hose. there is never any suction/vacuum present in a properly operating a/c system..
its probably going to be easier to find a whole pulley/bracket setup off a non-a/c engine..
Reply #2May 15, 2012, 08:10:14 pm
Quantum TD
  • 1195
« Reply #2 on: May 15, 2012, 08:10:14 pm »
I've got the bracket, and the hoses if you want to keep the AC setup. PM me for details.  I don't frequent the site as much as I used to.
