Author Topic: VW Dealer stumped in timing IDI pump  (Read 9149 times)
April 04, 2012, 09:09:18 pm
Jskiller
  • 5
« on: April 04, 2012, 09:09:18 pm »
And I am stumped also.......
A little bit of background on the car:
91 1.6 TD 5 speed 500,000km+/-
Always passed "air care" well above average.
Injector pump was replaced with a rebuilt pump about 100k ago (before I owned car).
Checked numbers on the injector pump and they appear to be the correct
068 130 109H
0405 494 206(182 stamped over 206...assume it was a number used by the rebuilder)
Car feels weak at low rpms, doesn't really come on until 2-2.k.
Temp climbs when pushed on long uphills, I always back off and slow down (just in case).
a/c disconected and pump unplugged, condensor removed from in from of rad
power steering, cruise control, made in germany(if it matters)
Mileage is ok, but not as good as other mk2's I have had 750km on 50L.....could get 1000 out of the 2 others.
Now for the problem:
Took the car into a VW dealer to have the timing belt done. (I suspected timing issue due to heat and low rpm weakness)
Timing belt was replaced, but they could not get the timing beyond 0.86mm.
Took timing pump pulley off to check that key was in place.
Tried moving belt one tooth, but then minimum timing available was too high at 1.35mm +/-
Does anyone have any idea what is wrong?
Could the cold start adjustment have anything to do with timing problem?
Is there an external adjustment that could have done this?
Or did the rebuilder just botch the rebuild up????
Thanks for any answers.
Reply #1April 04, 2012, 09:52:19 pm
Jskiller
  • 5
Re: VW Dealer stumped in timing IDI pump
« Reply #1 on: April 04, 2012, 09:52:19 pm »
Vancouver Island.
What do you suspect they were doing incorrectly?
From what I was told, they were maxing out the travel on the IP timing (moving as far as they could towards the valve cover)
Reply #2April 04, 2012, 10:00:25 pm
billybobf
  • 318
« Reply #2 on: April 04, 2012, 10:00:25 pm »
as I dont have a lot of experience here, but I would like to know if the belt being way to tight or too loose could be a problem? kinda annoying they took in a running car and now can fix it?
Reply #3April 04, 2012, 10:08:57 pm
Jskiller
  • 5
« Reply #3 on: April 04, 2012, 10:08:57 pm »
Car is running.
It is running the same as it was before I took it in (lacks low rpm power)
But the timing is incorrect.......and when they checked it before taking it apart, it was out also.
There is no more adjustment left in the timing and it still isn't in spec.
I am trying to figure out why this is the case.
Reply #4April 05, 2012, 07:40:00 am
Jskiller
  • 5
« Reply #4 on: April 05, 2012, 07:40:00 am »
Libbydiesel, that does make sense.
I will have to take some measurements for proof and see if I can get them to fix it for free.........
Does anyone know the diameter of the pump sprocket and the distance between the teeth on that sprocket?
I think I can figure out the slot length and distance between the bolts and pump centre.
Should be as simple as showing the degrees of rotation caused by skipping a tooth and the degrees of rotation available in adjustment.
Thanks
Reply #5April 05, 2012, 09:25:04 pm
  • 2932
« Reply #5 on: April 05, 2012, 09:25:04 pm »
Tell those wimps to loosen the injector lines at the rear of the pump so they can turn it farther/easier.
Reply #6April 05, 2012, 09:44:16 pm
Baron VonZeppelin
« Reply #6 on: April 05, 2012, 09:44:16 pm »
I agree with all the comments so far.
Probably a junior tech is assigned to your job.
Might even be his first time working with this old magic.
VW Diesels in USA haven't used this process in past 20 years.
there is an alignment index line (raised line in casting) on snout of Inj Pump -
it gets aligned with an alignment indentation on the metal backing plate of the timing cover.
From that point of neutrality - there should be plenty of room for adjustment to obtain the proper spec. The injection lines should be loosened - then the parameters set - as to mentioned above.
Then the spec set as desired.
Then lines re-tightened.
Reply #7April 05, 2012, 10:03:35 pm
billybobf
  • 318
« Reply #7 on: April 05, 2012, 10:03:35 pm »
also, they may have not loosened all FOUR mounting bolts. could be the flywheel side mounting bolt that they did not loosen
Reply #8April 06, 2012, 11:25:54 am
rallydiesel
  • 1880
« Reply #8 on: April 06, 2012, 11:25:54 am »
There must be someone nearby that can help you.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #9April 06, 2012, 12:22:46 pm
« Reply #9 on: April 06, 2012, 12:22:46 pm »
follow the kubvan link in my sig... i am thinking he is over in your area, the admin, and he knows how to set timming i beleive..
Reply #10April 06, 2012, 08:51:11 pm
Wayland
  • 364
« Reply #10 on: April 06, 2012, 08:51:11 pm »
Vancouver Island.
Where on VI are you? I may be able to help you. I have the tools and have timed many pumps. It's not hard.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #11April 12, 2012, 07:03:43 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #11 on: April 12, 2012, 07:03:43 am »
The dealer doesn't know what they're doing.
Sigh. ::)
Reply #12April 12, 2012, 08:17:16 am
« Reply #12 on: April 12, 2012, 08:17:16 am »
Sigh. ::)
x3
Reply #13April 17, 2012, 05:21:29 am
srgtlord
  • 797
« Reply #13 on: April 17, 2012, 05:21:29 am »
I wonder if the pump is 180 degrees out?
Reply #14April 17, 2012, 08:30:59 am
billybobf
  • 318
« Reply #14 on: April 17, 2012, 08:30:59 am »
wouldnt matter in getting correct timing at tdc. and probably wouldnt want to drive at all.
