Author Topic: filter to pump fuel line info needed  (Read 2636 times)
April 03, 2012, 05:44:51 am
derekp
  • 94
« on: April 03, 2012, 05:44:51 am »
my fuel line from the filter to the IP (92 eco diesel) is a black line factory crimped to a clear nylon line.
It appears to be "sucking air" at the crimp (I can actually move the black line around on the clear line at the crimp)
VW shows that line to be a 2 piece (using a hose clamp) where mine is crimped.
I need to replace the black line (mine is also quite dried out)
Has any of you done this without issue? I'm hesitant to cut the crimp off and try to put a 5/16 line back onto the nylon line - dont know if it will fit snug enough!
(and I have no "backup" in case this doesnt work!)
Any info appreciated...
thanks.
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
Reply #1April 03, 2012, 07:49:21 am
Re: filter to pump fuel line info needed
« Reply #1 on: April 03, 2012, 07:49:21 am »
Many of us have used the right sized line from an ATV or chainsaw shop. If you eliminate everything to the barbs on the banjo bolts and use a nice smooth hose clamp, like they sell on autohaus az, you will have no troubles. You can use diesel rated black hose, but you won't be able to see the air in it if it gets any.
Reply #2April 03, 2012, 07:56:07 am
« Reply #2 on: April 03, 2012, 07:56:07 am »
This thread has several fuel line suggestions.
Reply #3April 03, 2012, 07:59:10 am
derekp
  • 94
« Reply #3 on: April 03, 2012, 07:59:10 am »
I presume this means that those shops have metric sized clear line that stands up to diesel?
And it will fit over the barb fitting on the pump as well as the flare on the filter?
thanks!
The fleet
94 suburban (mine)
Reply #4April 03, 2012, 08:05:14 am
« Reply #4 on: April 03, 2012, 08:05:14 am »
thanks!
short answer,  YEP
Longer, bring a barb and fit to the line they have.
Reply #5April 03, 2012, 08:21:52 am
« Reply #5 on: April 03, 2012, 08:21:52 am »
I've not really found a noticeable difference between metric and U.S. fuel line sizes, they are really close and when clamped down, I personally don't think it matters. I've used "standard" sized fuel line on every European car I've owned.
Reply #6April 03, 2012, 10:51:00 am
« Reply #6 on: April 03, 2012, 10:51:00 am »
im with ya there buddy..
Reply #7April 04, 2012, 07:06:58 am
92EcoDiesel Jetta
« Reply #7 on: April 04, 2012, 07:06:58 am »
8 mm is 0.31496 inch
5/16 is 0.312
Don't worry about the 0.00296 difference. I don't think hoses are made to such tight tolerances lol.
